Turbo gone?
Old Jul 23, 2010 | 05:10 PM
diamondrst's Avatar
diamondrst
Question Turbo gone?
When trying to boost car makes a whining sound and releases white smoke but only when revved up has my turbo gone?
Old Jul 23, 2010 | 08:41 PM
diamondrst's Avatar
diamondrst
Any1
Old Jul 23, 2010 | 08:50 PM
Mike Kerbey's Avatar
Mike Kerbey
White smoke suggests water is getting into the cylindars.
If the turbo is squealing the blades are hitting the housing when on boost.
Wouldnt have thought the turbo would produce any white smoke though. Is it using water?
Old Jul 23, 2010 | 09:12 PM
Rob_DOHC's Avatar
Rob_DOHC
Kick her out the car and try again.
Rob,
Old Jul 23, 2010 | 09:34 PM
diamondrst's Avatar
diamondrst
Sorry it looked white but it is blue and the turbo sounds like it is hitting the housing and Rob she has been banned from the car loooooool
Old Jul 23, 2010 | 10:01 PM
Rob_DOHC's Avatar
Rob_DOHC
Best cheap mod you can make.
Old Jul 23, 2010 | 10:02 PM
Rob_DOHC's Avatar
Rob_DOHC
And aside from that, if its blue and your turbo is making funky noises i would say the turbo has had its day.
Rob,
Old Jul 23, 2010 | 10:12 PM
diamondrst's Avatar
diamondrst
Loool iv had enough of being told to "slowww down u fuking maniac" so i can now put my hybrid on now
Old Aug 2, 2010 | 11:16 PM
dave_s2_rst's Avatar
dave_s2_rst
Hi, rather than starting a new thread, I also have a question surrounding this.
Took off the bottom cooler hose and hose from turbo to metering unit and found quite a bit of oil, Also should there be any play in the turbo?
Old Aug 3, 2010 | 05:58 PM
dave_s2_rst
upski, anyone around essex willing to have a look? Its already off the car, cheers
Old Aug 3, 2010 | 07:53 PM
Rob_DOHC's Avatar
Rob_DOHC
Side to side play is okay (not too much) there shouldn't be much (if at all) in and out play.
My engine ran fine and the bores were not too bad on inspection and i had oil in the same hose. So tbh unless its a lot you are probably fine.
Rob,
Old Aug 5, 2010 | 10:04 AM
dave_s2_rst
just had a look at my turbo and noticed some obvious play side to side, also the actuator has been welded to the turbo? and cossie exhaust housing cracked on one side..(will grab some picts)
Now im stuck on what to do, how do I go about finding out whether this is an uprated turbo - What other turbo options do i have?
Current spec: 2.0 zvh, on let pistons/ 1.6 head with cough piper cough cam/ going onto cossie management/ radtec fmic.
Future plans are to go full zetec (approx in 1years time) so would ideally prefer a turbo which would be spot on (once fully mapped) on a zvh and zetec turbo.
cheers
Old Aug 5, 2010 | 01:53 PM
wilky's Avatar
wilky
Default turbo
hi mate ican have a look
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
