How to adjust rear camber
Hi
I have been truing to find out how to adjust the rear camber on my S2. Car is to be used on road and some trackdays.
Searching the forum i find people talking about H&R Triple C adjustment bolts and SPC camber adjusting bolts. Even googled the parts and found the H&R for escorts (but it is for the euro or US version
If for the euro escort, do they fit the rear setup or do i need to modifiy it to use these camber bolts ?
Someone told me that these bolts are already part of the RST rear setup, but i havent seen it
And.. is it worth it if you already have the adj. TCA's up front ?
)If for the euro escort, do they fit the rear setup or do i need to modifiy it to use these camber bolts ?
You want:-
S1 or RS16i front rollbar
Adjustable TCA's
Coilovers
Adjustable top mounts or cosworth grp a top mounts.
Rear 6 link adjustable tie bars and link setup.
Disks all round with a 250bhp engine and you will have a monster.
Adjustable TCA's
Coilovers
That wasn't really the question was it!!
Seems a very over-the-top solution to a simple question.
I ran SPC Camber bolts on mine, they cost <Ł20GBP and will give a moderate amount of camber adjustment. They are a direct fit into standard RST rear hubs and will obviously need setting up once fitted.
They suit what you're after perfectly.
Hi Christian
Thanks, just what i needed to know.
Would you by any chance know where to buy thise bolts online in the UK ?
To Versus.... that would be a really nice setup.. if i was a millionare and didnt have to go through a danish MOT
155lee
Sep 6, 2016 11:10 AM
