Ford Focus ST Parts for Sale Only Ford Focus ST parts here please. Register for a Gold Membership to list!
ST170 sump modified to fit any zetec block.
Old Jul 21, 2010 | 10:28 PM
Luca's Avatar
Luca
Lukesville
Default ST170 sump modified to fit any zetec block.
I have a ST170 sump which will fit any zetec block silver or black top.
(Standard will not clear the main caps on silver top)
Also has oil return pipe fitted and a -10 fitting on the steel lower sump.
Ideal for use on a turbo zetec build running st170 gearbox.
The half shaft mounts straight onto it as its integrated into the sump.
Pics to follow.
£80 shipped.
Old Jul 22, 2010 | 11:16 PM
andysfatrs's Avatar
andysfatrs
get some pics up luke, interested.
Does this come with the pick-up pipe?
You mention the return pipe is fitted and a -10 fitting, what is the fitting for?
Old Jul 23, 2010 | 09:02 AM
Luca's Avatar
Luca
Lukesville
As requested.
The lower - 10 fitting was the oil return from the breather.
Old Jul 24, 2010 | 09:47 PM
Bomber's Avatar
Bomber
Did you have a new bracket made up to fit your silvertop block for the ST shaft?
Old Jul 25, 2010 | 07:04 AM
Luca's Avatar
Luca
Lukesville
Yes mate, new bracket looks like this...
(Trial Fit) before spacer machined.
Old Jul 25, 2010 | 09:16 AM
Bomber's Avatar
Bomber
Can you get another made?
Old Jul 25, 2010 | 10:30 AM
andysfatrs's Avatar
andysfatrs
If you can luke, i would also be interested
Old Jul 27, 2010 | 09:28 AM
Bomber's Avatar
Bomber
So that's a no then?
Old Jul 27, 2010 | 09:49 AM
Luca's Avatar
Luca
Lukesville
Im sure another can be made, but it wont be for a while as this was made in situ on the car.
Im not able to remove it at the moment to have copied.
If you wanted one then I can only suggest booking your car into JKM and having them make one for you.
RUBY123
Oct 22, 2023 12:04 PM
kosienutter
31
Aug 22, 2015 09:55 AM
track.focus'd
Aug 12, 2015 05:53 PM
Focus Steve
Ford Focus Range
Aug 3, 2015 09:09 PM
lockie
Jul 31, 2015 10:03 PM
