help rs turbo floor pan needed o/s/r
Can any1 tell me where i can get a s2 rear left floor pan from ive tried all the panel companys and nobody seems to have them any nudge in the right direction would be much appreciated thanks
hi,i got 1 2 months ago from ian at rsturbospares.com (think thats it),was either Ł28 or Ł38.i have his number in my phone,ill post it at teatime,im on nightshift and dont have my phone here.
find someone that sells Hadrian panels. ring 02476368010. it's coventry. they should give you there nearest dealer. part no 0-30 27 302 or 303. one's n/s/r the other's o/s/r.
I have found out today that the floor pans are no longer made
i tried every supplier in the uk the only 1 i found was a floor to sill panel at rs turbo breakers and its no good to me
thanks for the help
thanks for the help
did you speak to ian??it wasnt a hadrian floorpan i got,it was another make.i think youre right about hadrian not making them.i know a guy with 4 ford gen floorpans,he knows what they are worth though.cant you make up the bits you need from sheet steel and weld them together?have you tried ebay?i repaired my n/s that way.post up a pic of how bad it is.
they have them listed on here not sure if they still stock them tho
http://hadrian.dominohosting.biz/had...2%2F86-08%2F90)
Gadget
Ford Escort RS Cosworth
Aug 14, 2015 07:19 AM
Gadget
Aug 13, 2015 08:19 PM
