Keep finding loads of oil underneath my car cant c where its coming from it is also sitting on the inlet manifold any ideas where ot could be coming from
On start up i hav to rev it for it to start otherwise it will start then die would this have somthing to do with the breather iv got a baileys one on it
it won't be a breather making it run a bit funny then, as when you blank that breather at the metering head it no longer creates a air leak on the induction system if a breather splits or oil cap comes off etc
if its MFI it should. MFI runs under a vacum created by the metering head. some people block this off then it can vent to atmosphere. pros and cons for both to be fair.
