turbobills s2
Old Jul 20, 2010 | 07:53 PM
turbobill's Avatar
turbobill
Default turbobills s2
well i bought the car back in october last year and ever since been doing bits to get it ready
i havent got any pictures of the car how it was, but its pretty much the same, just needed a bit of welding
i have done all this my self and its my first ever go
little patch in the boot
all welded up
and painted
patch on the passenger seat mount
all welded upp
patch under the rear light
i dont seem to have a picture of the patch but here it is filled upp
then sanded down
patch on the left rear light
and filled upp
then primered
and painted
front cross member
before
after
primered
and painted
bit of patch work on inner sills
bottom of left rear arch started of as a little hole
and ended upp
havent got a picture of the patch but here it is in primer
and paint
finished
then the drivers sill started of as a little hole
time i finished prodding with a screwdriver
so new sill
and painted
few random pictures
before
after
Old Jul 20, 2010 | 08:02 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
well done mate looks like youve had your work cut out there hope you keep going and keep us updated with pics!!
Old Jul 20, 2010 | 08:06 PM
turbobill's Avatar
turbobill
then i decided to take the engine out
i ahvent got a picture of the old one
i bought a new one
before
and then painted upp
whilst it was out i cleaned the engine bay and took the abs outt
new engine going inn
and its inn
alternator bracket all painted
and starter motor painted
then i took the chrome rocker cover off
and got another one
rubbed it down
then paint
first coat
second coat
then i forgot to take pictures of the third and fourth
but here it is on
just need to paint the cross over pipe and then get a downpipe sorted out.
any comments welcome
Old Jul 20, 2010 | 08:17 PM
turbobill's Avatar
turbobill
heres how it is atm
and after a good wash n polish
Old Jul 20, 2010 | 08:32 PM
turbobill's Avatar
turbobill
thank you mate, well i shall keep going cos it nearly done now, and i shall keep you all updated
Old Jul 22, 2010 | 09:07 AM
turbobill's Avatar
turbobill
small update
painted the crossover pipe yesterday
heres a few pictures
before
first coat
second coat
and third coat
anycomments welcome
Old Jul 22, 2010 | 09:13 AM
billybigspuds's Avatar
billybigspuds
gonna get myself shot here but in all honesty im not that impressed with the bits you have done, little more effort with prep required, fair bloody play too ya for having a go, more than most would do
Old Jul 22, 2010 | 09:15 AM
turbobill's Avatar
turbobill
what needs more prep then?? btw im only 16, its my first ever go at doing this kind of thing, i bought the car myslef, and ive had no help what so ever with it
Old Jul 22, 2010 | 01:21 PM
markc's Avatar
markc
Fair play for trying but id suggest a little research on what you need to do to achieve better results. pop your self down to halfords and grab yourself a bodywork book i think its from haynes. it will show you what the weld should look like etc its great for ppl starting out. (it looks like you havnt been using primer before painting either so itll all flake off in no time).
Old Jul 22, 2010 | 03:06 PM
turbobill's Avatar
turbobill
i used primer for all the bodywork, i went through tins of it,as for the cross over pipe and rocker cover, i didnt use primer, but im going to be doing those again anyways
Old Jul 22, 2010 | 05:02 PM
Good to see you having a go ,at 16 aswell
Old Jul 22, 2010 | 05:19 PM
cossie j's Avatar
cossie j
Old Jul 22, 2010 | 05:37 PM
turbobill's Avatar
turbobill
thanks for the comments : ) i know its properly not the best but im learning and im happy with it
R6Franky
Apr 9, 2010 04:48 PM
