does any1 know how to get big power from a rs2000????
turbo conversion or what???????? any1 know anything, thanks
my mate has the same car so i will be watching for others advice on it, i would say chipped ecu, set of upgraded cams and an upgraded clutch would be a good start mate, full s/s exhaust, remove cat, ram air induction kit, maybe stripped out?
cheers m8, but kinda looking for big power to be honest
i want over near to 300bhp
hence why im asking about turbo conversion
but saying that depends if its possible
what sort of bhp would i get if i done the above? its only 150bhp standard
anything is possible my friend
tho im no expert on turbo conversions but i know it can be done. with just what i mentioned i would say 190-200 bhp
to go towards 300 you will need forged bottom end too
hi you can turbo an rs2000 but your talkin alot of money there was a feature in a ford mag about a red rs2000 with a 2.3 galaxy bottom end turbo'd i think it was over 300 at about 12psi but i could be wrong if you register with http://www.rs2000-16v.com/ im sure there a turbo conversion guide on there an performance upgrades you can do other than turbo. hope this helps
forged bottom end, t35, managment, its big money just for those then theres all the little bits and pieces youll need, the gearbox conversion with a diff in so itll grip and take the power, suspension and brake upgrades etc etc
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
deathrider666
Sep 28, 2015 06:12 PM
