Brake warning light stuck on - help pls?
Old Jul 17, 2010 | 01:59 PM
AndyPen's Avatar
AndyPen
Default Brake warning light stuck on - help pls?
Just running through some of the possibilities and would appreciate any ideas lads?
Car been off the road for 6 or more months. Brakes were disconnected and blanked off with hardly any fluid loss... all bled and feel good. ABS light goes off as it should, its just the handbrake warning / fluid warning one that is staying on.
What I've tried so far includes:
Fluid level is good and have changed the level sensor / reservoir cap switch with my saff one (which works on that car)
Pulled off the abs pump connection and reconnected a few times (but need to check to hear if this running once I've left it awhile).
Pulled the handbrake on and off a lot in case the switch is sticking - think this is under the centre tunnel plastics if I need to get to it???
If I am overlooking something obvious lads - would appreciate a nudge please - dreaded MOT on Monday ;(
Old Jul 17, 2010 | 02:16 PM
martysmartie's Avatar
martysmartie
I guess the car was stored with the handbrake off? If it was stored with it on it could easily be the switch has jammed. The switch is indeed under the centre console and is just an earth for the bulb. This is what I would be looking at.
Martin
Old Jul 17, 2010 | 02:20 PM
jon@work's Avatar
jon@work
Remove the 3 pin connector from the brake fluid reservoir and see if the brown/green wire (that goes to the handbrake switch) is earthed with the handbrake off. If so, you may have put a trim screw (along the sill on the driver's side) through the wire ?
Old Jul 17, 2010 | 04:02 PM
cossie604's Avatar
cossie604
I wouldnt worry about that lamp with regards the mot Andy
Old Jul 17, 2010 | 04:51 PM
bubs_rsturbo's Avatar
bubs_rsturbo
and if u still cant find the problem.....take the bulb out
Old Jul 17, 2010 | 10:06 PM
AndyPen's Avatar
AndyPen
Had a good fiddle around and kind of gave up. Handbrake switch looked good and couldn't work it out.
Just gone out to bring the car into the grarage and it went out!!! Cossie wiring gremlins!!!
Thanks for all the ideas and help - may still need them but for now it works
yatta
May 21, 2016 10:31 PM
fuzzy
Sep 4, 2015 10:11 PM
hopper350
Sep 4, 2015 12:53 AM
cossirob
Sep 3, 2015 09:17 PM
turbowag
Sep 3, 2015 08:07 AM
