10W60
Old Jul 15, 2010 | 07:25 PM
S1 Combi's Avatar
S1 Combi
Default 10W60
Would 10W60 be safe in an rs turbo?
Old Jul 15, 2010 | 07:27 PM
pee vee's Avatar
pee vee
Bit heavy IMO
Old Jul 15, 2010 | 08:59 PM
Rick's Avatar
Rick
good for hard use.
Old Jul 15, 2010 | 10:55 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
if it's fully synthetic and for track use then yes it'll be good, not so great for a daily.
try some millers fully synthetic 10w40, or 10w50 if you do the odd track day.
Old Jul 17, 2010 | 02:05 AM
Micky's Avatar
Micky
I used Castrol RS 10W/60 in my trackcar RST and never had a problem.
Old Jul 20, 2010 | 07:35 PM
S1 Combi's Avatar
S1 Combi
just wondered about using something a bit thicker as when my fans come on the oil light flash's on
Old Jul 20, 2010 | 08:42 PM
pee vee's Avatar
pee vee
Don't mask the problem, how hot is it getting!?
Old Jul 21, 2010 | 11:54 AM
S1 Combi's Avatar
S1 Combi
The guage is only going up to around 3/4 then the fans come on and it cools down,its never over heated or anything so its not gettin excessivley hot
Old Jul 21, 2010 | 02:19 PM
Karlos G's Avatar
Karlos G
Balls Deep!
You have low oil pressure at idle, fans coming on drop idle a bit lower.............. bottom end rebuild is most likely on the cards mate
PeterLucas
Sep 21, 2015 11:36 AM
Sierrasideways
Nov 13, 2014 08:02 PM
Cossie Sean
38
Jan 20, 2014 07:55 PM
Rogeyboy
Jun 4, 2013 04:00 PM
MattOz
Feb 26, 2009 06:24 PM
