saph handling
Old Jul 15, 2010 | 01:09 PM
paulgsi's Avatar
paulgsi
Default saph handling
my saph is a little bit unsteady on the road wen i go over 85 ish and above , wen i would hit a bump it would just unsteady it a tad bit - like the steering is very light on it , i have ahmed springs and konis , poly tca arms and all the rear is poly bushed , the same road i can take my astra gsi out on it at keep it planted at 110 or more no bother good and steady , anyone have any suggestions as to why the car gets this way with speed - wheel bearings and track rod ends ar all perfect from wat i can see
Old Jul 15, 2010 | 01:14 PM
johnandhissaffy's Avatar
johnandhissaffy
white fords look best
prop might be out of balence are you getting a lot of noise from inside the car
Old Jul 15, 2010 | 02:01 PM
paulgsi's Avatar
paulgsi
no its perfect inside the car its just that the steering is very light in it at speed compared to other cars i drive , , dont know what it is its like im hanging on to the steering wheel and watching the road just to keep it straight , its not all over the place but it just slightly chaanges very easily , compares to other cars i drive on this road where i could safely have 1 hand on the wheel at the same speed , the car just dosent feel planted enough at the front, id just like to have it more solid
Old Jul 15, 2010 | 03:27 PM
davecosworth's Avatar
davecosworth
IM BACK
try chaning the top mount bearings and bush's on the front
Old Jul 15, 2010 | 05:25 PM
Try adjusting the tyre pressure either way a few psi, do you have a poly diff mount ?, if not get one asap.
Old Jul 15, 2010 | 11:00 PM
paulgsi's Avatar
paulgsi
tyre pressures ? interesting - i will check that indefinatly yea i fitted a poly mount a few weeks ago - great job so they are
Old Jul 15, 2010 | 11:57 PM
johnandhissaffy
it is almost 20 years old even i wobble a little bit lol
Old Jul 16, 2010 | 12:04 AM
botters's Avatar
botters
competant bodger
do you still have the rose joints on the rear arms or have these been replaced with poly too? as the polys in place of the rose joints on the rear can cause the front to wander believe it or not as it upsets the rear geometry and effectivley makes the car crab
Old Jul 16, 2010 | 07:05 AM
Try fitting a 22mm rear ARB, this will massively, and I mean massively improve stability, I can do,(on a private road of course)150 round long sweeping bends doesn't break a sweat at all, unlike before I wouldn't barely have gone over 100-110 on the private road, it really is like night and day the difference.
wowk
Mar 30, 2021 07:49 PM
Rsmat
89
Oct 12, 2015 07:50 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Adam-M
Was It You?
Oct 1, 2015 07:55 PM
Russ Payne
Sep 25, 2015 08:29 PM
