What pistons
Old Jul 13, 2010 | 08:09 PM
BRAM's Avatar
BRAM
Default What pistons
What pistons and comp ratio would be best suited for around the 500 horse mark?
Old Jul 13, 2010 | 09:43 PM
Danny @ Enhanced Performance's Avatar
You can use mahles mate with just valve cut outs and if the heads got good meat that will be around the 7.8.1 cr mark and will be fine..
Id prefer to use a cosworth short skirt piston and that will also last longer but of course down to money???
What turbo etc you thinking of using??
cheers danny
Old Jul 14, 2010 | 09:27 AM
As said mahle are fine, and a excellent piston, need to get valve pockets done as you will need a different inlet cam ideally for 500bhp.
One thing you should consider is whether you intend to do any further mods power wise, as this could affect the CR needed at present.
As a general rule as high as you can get away with is the answer, as this will give far better off boost power, married to a decent mapping job.
Old Jul 14, 2010 | 10:05 AM
LHD220Turbo's Avatar
LHD220Turbo
as said standard mahle's are fine with pockets
but if you want to over spec then CP pistons
Old Jul 14, 2010 | 04:54 PM
Sonic Boom's Avatar
Sonic Boom
I've got CP's in mine
Rich
Old Jul 14, 2010 | 05:39 PM
BRAM's Avatar
BRAM
cheers danny
Thanks for the replys everyone, we have already got mahles in with valve cut outs but think they may be damaged due to my mate going warpe speed and the timing belt coming off (tensioner failure) bent all 16 valves and the pistons dont look to clever.
Going to get them sent to harvey for a check see what he thinks.
The rest of the spec is
200 block .5 oversize bore
all lightend and balanced bottom end with arp bolts
standard comp mahles with valve cut outs (if still ok)
ported and polished head
bd 14 inlet
bd 10 exh
vernier pulleys
gt 30 turbo internal wastegate
2wd manifold
sweedish inlet with spacer
83lb siemens
coil pack
launch control + anti-lag
closed loop
500 cooler
alloy rad
turbo cooler
oil cooler
pas cooler
Cant remember any more, was booked into motorsport developments on sat for live map but not going now just back to bits AGAIN
Old Jul 14, 2010 | 06:27 PM
Best of luck with the rebuild, let's hope your pistons are ok, saves you a bit of money that way!!
Old Jul 14, 2010 | 06:51 PM
bd 14 inlet
bd 10 exh
vernier pulleys
2wd manifold
83lb siemens
coil pack
closed loop
500 cooler
alloy rad
turbo cooler
oil cooler
pas cooler
Nice spec there and all good,pistons should be fine maybe just a bit of de burring needed..
Id expect it to make 450 ish hp and around the same torque,nice fast road spec!!
cheers danny
Old Jul 14, 2010 | 07:00 PM
BRAM's Avatar
BRAM
cheers again,
What else do you think is needed or needs changing to get it pushed upto around 500bhp.
Steve
Old Jul 14, 2010 | 07:15 PM
LHD220Turbo
what turbo is that? gt3076?
what comp ratio you using? i personally would have a standard exhaust cam, no need to change.
Old Jul 14, 2010 | 07:27 PM
cheers again,
Steve
No need to change the ex cam a bd 10 isnt much bigger than std anyway..
Id go for a bigger inlet cam 11mm lift and 280 duration and youl need a gt 35 for 500+hp..
Infact depending on the head spec with the cam iv just mentioned on the gt 35 you could do over 550 hp..
cheers danny
Old Jul 14, 2010 | 09:09 PM
BRAM's Avatar
BRAM
not sure what turbo it is mate its not my car its my mates (martin willetts+) and its standard compresion.
Old Jul 14, 2010 | 09:21 PM
LHD220Turbo
f he wants 500hp then he'll need the 3076, but if its the 3071 then he'll struggle to get 500, more like 450
the 3071 makes a brilliant road car turbo, when i get another cossie, i'll be going down the 3071 route
Old Jul 14, 2010 | 09:37 PM
BRAM's Avatar
BRAM
ok mate i will find out tommorow and let you know.
Nov 1, 2015 06:53 PM
little bram
Oct 4, 2015 12:13 AM
deathrider666
Sep 28, 2015 06:12 PM
timsrs
22
Sep 24, 2015 08:14 PM
ajamesc
Sep 8, 2015 06:51 PM
