auto dim rear view mirror
i'll get back to you on this or remind me in a day or two as i have a how to on this on other forum.
ok you have 3 wires from the multiplug of the mirror.1=is black which is earth,then you have 2 green & red wires,one of em is for reverse which is not needed as it does is switches off the mirror for clearer view & not dimming it if strong light hits it,as there's off button on mirror already,the other green/red wire goes to i think pin 16 on (i'll double check this ) on headlight switch so it turns the mirror on when sidelights are on. its a doddle ,i'll do how to on this when time permits me.yunii
thats great yunii ill check this out when i get 5 mins just quick question ive noticed where the wiring comes out of back is there a cover so you cant see the wires trailing up to the roof
cheers again
cheers again
