rs turbo juddering
Old Jul 12, 2010 | 06:46 PM
RS CR41G's Avatar
RS CR41G
Default rs turbo juddering
please help! the last few months my car as been juddering really bad when driving.its really only started doing it since fitted the diesal gearbox.could it be this? ive changed the clutch but still the same.ive checked the mounts but ok.really doin my head in now.if any body could help whos ad the same problem would be great thanks
Old Jul 12, 2010 | 07:41 PM
RS CR41G's Avatar
RS CR41G
just been told it could be my clutch cable on the way out! wot u reckon people?
Old Jul 13, 2010 | 05:43 AM
gpm89's Avatar
gpm89
Does it judder when you change gear? My XR3i did this due to f**ked gearbox mountings!
Old Jul 13, 2010 | 05:17 PM
RS CR41G's Avatar
RS CR41G
yeah mate it does it when change gear and when just cruiseing along,but no and again it pops out of gear only 1st gear when pulling off and 5th gear when was on motorway,
Old Jul 13, 2010 | 05:21 PM
c2ssv's Avatar
c2ssv
the best 4x4xfar
alrite mate its doin that cos it wants a cossie lump ha
Old Jul 13, 2010 | 05:50 PM
Oranoco's Avatar
Oranoco
Jumping out of gear would be indicating a sick box. Might be time to start looking for a new one and this time get a proper one as the diesel one is shit
Old Jul 13, 2010 | 06:02 PM
gpm89's Avatar
gpm89
Also... just realised my gearbox was also a diesel one and that used to pop out of 3rd and whine like a bitch in first. I found the easiest way to test for knackered gearbox mountings is by getting a thick bar and wedging it between the gearbox and the gearbox crossmember and pushing down... i.e trying to lift the gearbox up with leavarage. If it has movement then you know its the mountings..... Or if ur lucky it could just be that the nuts have come loose. But very unlikely.
Graham
Old Jul 13, 2010 | 09:28 PM
RS CR41G's Avatar
RS CR41G
sound, il check the mount in morning if they am ok then its gota be the box,got a new one coming soon fully rebuilt,you am rite thow diesal box am crap
Old Jul 19, 2010 | 01:18 PM
stevo123's Avatar
stevo123
Check clutch condition also while box is off.
Old Jul 19, 2010 | 04:58 PM
RS CR41G's Avatar
RS CR41G
ive changed the clutch but still the same ive checked the mounts and they am fine,ive also puit new clutch cable on and its still doin it,its gota be the gearbox
JK12
33
Apr 26, 2021 12:09 PM
RSBryden
Sep 6, 2015 08:39 PM
cozzzzy power
Sep 4, 2015 08:14 AM
turbowag
Sep 3, 2015 08:07 AM
Jerry Ryan
Sep 2, 2015 08:02 PM
