i need the adjusting screw on a s2 metering unit as mine has a bolt in it causing an air leak. can any one help im in bromley or south london. please call 07817803605
Hi mate, the adjusting screw should be under the bolt, a small allen key will adjust it. If the bolt is causing an air leak use some ptfe take around the threads.
