wat cam?
Old Jan 19, 2005 | 02:47 PM
phil21's Avatar
phil21
Default wat cam?
i have got a piper 285t cam in my s2 but its now done 25000 miles and dont pull aswel as it did,how long do they last? thinking of getting a standard cam next.running 18psi will standard cam work well with that boost?
Old Jan 19, 2005 | 04:48 PM
Moonie's Avatar
Moonie
Is there excessive noise from the top of the engine/cam?
Old Jan 19, 2005 | 05:08 PM
rsnitrouskev's Avatar
rsnitrouskev
the cam u already got is a excellent cam running 18 psi unfortuantly they dont last long 2 yrs max depending how drive it try a cvh 35 thats what im using in mine was recomended it i think kent r better than piper but thats debateable
Old Jan 19, 2005 | 07:43 PM
james_birch's Avatar
james_birch
very debatable!
Got for a piper T2 there more suited to higher boot applications! (14psi+)
i have a 285t in mine and love it tho next i will go for a T2
Or if you dont mind your engine being late on power newman cams are ment to be good but have solid lifters! so take more time to fit!!
Old Jan 19, 2005 | 08:38 PM
bassboy's Avatar
bassboy
try a Kent CVH34....gives EXCELLENT mid-range power and pulls through to redline not as lairy as the cvh35 but the mid range gains are excellent
bassboy
Old Jan 19, 2005 | 10:32 PM
GrimmeRS2K's Avatar
GrimmeRS2K
ive got the kent cvh 34 in mine, excellent cam, for laggy rs turbos, pulls like a train in mid range and has a early power band 1.5k revs.
Old Jan 20, 2005 | 10:21 AM
Rallyesport's Avatar
Rallyesport
I'm fitting a CVH34 in my engine. I choose it for the good mid range and I'm glad to hear it works as intented.
Old Jan 20, 2005 | 02:43 PM
220TC's Avatar
220TC
yes, but how long will it last !!!!!!
Old Jan 20, 2005 | 03:35 PM
phil21's Avatar
phil21
the kent 34 sounds good as i am after low torque rather than reving the hell out of it.
Old Jan 20, 2005 | 04:02 PM
james_birch
piper 285t is a low lag cam!
Old Jan 20, 2005 | 05:21 PM
rsnitrouskev
like i said very debateable
Old Jan 22, 2005 | 11:28 AM
Rallyesport
Word, reving the CVH is more scary than fun. Drivability is not for women, it means faster lap times and faster 0-60.
bobsworth
77
Mar 24, 2016 09:30 PM
Mc5506
Oct 5, 2015 09:57 PM
