missing sensor ?
Old Jul 7, 2010 | 10:04 PM
Biffin28's Avatar
Biffin28
Default missing sensor ?
help!!
does anybody know where the coolant temp sensor is on my s2 ?.
mine doesnt appear to have 1,
+ if anybody has any good ideas why my car runs rough after about 5mins of running it would be much appreciated
Old Jul 7, 2010 | 10:48 PM
xr2wishy's Avatar
xr2wishy
Bodger of Blackburn
have you really looked for it?
it's under/on the inlet manifold, can't really see it from above, but you can from underneath.
Old Jul 8, 2010 | 01:32 PM
Biffin28's Avatar
Biffin28
Default confused.com
Have looked everywhere at back of head.
Nothing seems to match up with the new sensor i have, apart from a plug that is not being used?. Which makes me question if i have 1 or not. The new sensor has a round two pin type fitting, everything on or under the manifold has an injector type plug. or have i got the wrong sensor?
Old Jul 8, 2010 | 09:45 PM
project rs's Avatar
project rs
need a pic to see what you've got
Old Jul 9, 2010 | 11:38 AM
DannoRS's Avatar
DannoRS
RS Turbo
Coolant temp sensor is at front of the engine, right hand side of exhaust manifold
Old Jul 9, 2010 | 12:36 PM
dangerousbrian's Avatar
dangerousbrian
thats what i was thinking too..tiny little push on connector im sure
Old Jul 9, 2010 | 12:53 PM
studabear's Avatar
studabear
thats the 1 for the gauge the single wire item in the head
Old Jul 9, 2010 | 01:04 PM
phil_rs's Avatar
phil_rs
yam yammer
You're looking for a yellow sensor underneath the injector rail
Old Jul 9, 2010 | 01:07 PM
DannoRS's Avatar
DannoRS
RS Turbo
Yep.. one on front of the head by exhaust manifold is for the gauge. Fan switch is on thermostat housing also
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
gambo08
Feb 4, 2016 10:49 PM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
Fil
Sep 30, 2015 12:08 PM
