Fuel Pump!!!???
it all depends on how much power you're running, or more importantly your fuel requirements.
get it on the rollers and see if it can cope.
mine did fine on my zvh for a bit till i upgraded injectors to 630cc ones and whacked the boost up to 23psi, so i changed to a 979 pump just in case before i did the later, only flows 165litres per min or something like that, but better than the 4wd cossie pump which only did 130litres per hour.
JK12
33
Apr 26, 2021 12:09 PM
155lee
Oct 24, 2015 11:11 AM
wheelwizardrefurbs
Sep 23, 2015 09:21 PM
