Who's moved up from a .48 housing on a T34 to a .63 and??
Old Jul 7, 2010 | 05:50 PM
Staffi's Avatar
Staffi
Default Who's moved up from a .48 housing on a T34 to a .63 and??
What was spool up differences like please?? i know top-end will obviously be better, just want to know what/where you were/are coming on boost etc...
Old Jul 7, 2010 | 07:13 PM
3dormatt's Avatar
3dormatt
Had a .48 on my old 3 door and now have a .63 on my Escos. the .63 does feel slighlty slower to spool up, starts boosting around 3-3250 and full chat by around 3600-3750rpm
Hopefully this can be improved when I have it re-mapped
Old Jul 7, 2010 | 07:25 PM
james kiely's Avatar
james kiely
mines on a .63 pete and has been livemapped ,is a bit sluggish to pickup but when it does it fookin flyes mate
Old Jul 7, 2010 | 07:41 PM
Karl 3dr's Avatar
Karl 3dr
You need my old TT T38 Pete!! lol
Old Jul 7, 2010 | 07:54 PM
KSA-Cossie's Avatar
KSA-Cossie
Tbh,i didnt find the move from a .48 all that laggier.
Old Jul 7, 2010 | 08:11 PM
andy130's Avatar
andy130
my brothers escort is on a .63 its starts making boost before 3k, BUT when it comes on boost it pulls strong,
Old Jul 7, 2010 | 08:41 PM
james kiely
ive never being in a .48 kev ,i thought tnhey were real punchy like petes
Old Jul 7, 2010 | 08:45 PM
KSA-Cossie's Avatar
KSA-Cossie
I t was punchy james but i didnt find the .63 that much laggier.
Old Jul 7, 2010 | 08:58 PM
Ebonycossie4x4's Avatar
Ebonycossie4x4
i had a 48 on my saff and a 63 on my escos that i had both at the same time...
I prefered the 48 as it was far less laggier IMO
Ebonycossie4x4
Get the 38!
Old Jul 7, 2010 | 09:02 PM
Staffi's Avatar
Staffi
Originally Posted by Ebonycossie4x4
Get the 38!
To both replies..............NO..............
Remeber, i've been there done that..hated the fooking thing...
Staffi's Avatar
Staffi
That sounds good to me..........
Old Jul 7, 2010 | 09:08 PM
Sonic Boom's Avatar
Sonic Boom
Get a T66, now that's a mans turbo!
Rich
Old Jul 7, 2010 | 09:13 PM
Staffi's Avatar
Staffi
Rich
You couldn't even keep up with my T3 @ Brunters Rich...
Old Jul 7, 2010 | 09:15 PM
boXXer's Avatar
boXXer
GASH!
i had the .48, then moved to the .63. Loved the punch from the .48, but when i fitted the .63 and had it remapped, the punch is unbelievably hard! deffo a bit more laggy, and annoying at times to be totally honest, but i wouldnt change back.
It leaves my mates gollardo standing too
Old Jul 7, 2010 | 09:17 PM
Sonic Boom's Avatar
Sonic Boom
If I recall I was on 3 pistons and still catching you
Rich
Old Jul 7, 2010 | 09:18 PM
Staffi's Avatar
Staffi
Rich
I still have my 4 pistons though......
Edited to say,
How is the build coming along Rich??
Old Jul 7, 2010 | 09:22 PM
Sonic Boom's Avatar
Sonic Boom
Edited to say,
Pretty good should have it running by the weekend almost altogther now.
It now has a few more choice modifications
rich
Old Jul 7, 2010 | 09:24 PM
Staffi's Avatar
Staffi
Who's mapping it Rich???
Old Jul 7, 2010 | 09:31 PM
Sonic Boom's Avatar
Sonic Boom
Hopefully Martoon
Rich
Old Jul 7, 2010 | 09:45 PM
D16PJM's Avatar
D16PJM
if you didn't like your 38 and worried about lag i would stick with the .48 as your not chasing big numbers just a bit more pull/speed.
Pete
Old Jul 7, 2010 | 09:49 PM
Karl 3dr's Avatar
Karl 3dr
Haha, i had a feeling you'd say something like that!!
Old Jul 7, 2010 | 09:59 PM
james kiely
as you know pete,the cams were all wrong in g88 for the t38,have you had a run out in a t38 atall ,i never have but have heard great reports on them be it not as good as the gt30,s
Old Jul 7, 2010 | 10:45 PM
COLEYST200's Avatar
COLEYST200
Pete do you wont to go out for a spin in my 3dr as i have a T34 with .48 on it
Old Jul 7, 2010 | 10:58 PM
Thanasis's Avatar
Thanasis
a.55 maybe is the best choice, it can approach about 400-420hp,and less lag than .63,some cosworth builders prefer this e.housing
Old Jul 8, 2010 | 04:40 AM
COLEYST200's Avatar
COLEYST200
its getting hold on that size which is hard in the uk mate
Old Jul 8, 2010 | 07:41 AM
I don't find the .48 lacking at the top end, not terribly so anyway.
I must admit when I had £300 worth of porting done, it made a HUGE difference to power above about 5500, pulls hard all the way to the softcut at 7300rpm(hardcut 7600), was well worth £300, improved everywhere, as head as std is a bit of a disaster.
Old Jul 8, 2010 | 12:02 PM
Staffi's Avatar
Staffi
James, very true mate, engine was specced for a T4 really....
Ian, thanks for the offer mate.. i've had 2 cossies with the .48 housing mate, never the .63 that's why i was asking..
Tab, what porting was done for that cost excuse my ignorance?? i thought headwork was always around £800-1000 ??
Old Jul 8, 2010 | 12:11 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
doing this myself once car is back together,does anyone know where to get the 63 housing for my t34? Rang turbo technics but they can only do 55
Old Jul 8, 2010 | 12:25 PM
Staffi's Avatar
Staffi
Try CR Turbos fella..............
Old Jul 8, 2010 | 12:51 PM
SelbyRST's Avatar
SelbyRST
4x4 SAFF
will do,thanks
Old Jul 8, 2010 | 01:46 PM
jammerrs's Avatar
jammerrs
whats the difference between soft and hard cut?
Old Jul 8, 2010 | 04:19 PM
It was I'm 99% sure just some de shrouding of the exhaust port, as person who did it(Damico 01953 717784), said they are a bit of a disaster flow wise for performance, situated about 5 miles from Snetterton circuit.
The next step is another £300, which he says will improve all over the rev range again but even more, it really has made a surprising difference esp at top end where it used to run out at 5500 or so, pulls a lot harder to this and beyond, keep hitting limiter in 4th dead easy.
Old Jul 8, 2010 | 04:27 PM
Hi,
On my ecu(emerald K3) the soft cut uses ignition retard and fuel pulse cuts to let you know the(user) pre set limit is reached, you can drive through it if need be, but when the hard cut limit you set is reached it cuts all sparks and all fuel pulses, till below that rpm set.
I also have a buzzer instead of the shift light ran from the ecu at 6400.
Old Jul 8, 2010 | 04:51 PM
Staffi's Avatar
Staffi
Interseting info that Tab, cheers fella.....
Old Jul 8, 2010 | 05:10 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Just get the GT30 in parts for sale
Steve
Old Jul 8, 2010 | 05:57 PM
RSGARETHW's Avatar
RSGARETHW
always working
cant be arsed reading all that pete just get a t34 .55 best of both worlds then
Old Jul 8, 2010 | 06:03 PM
Staffi's Avatar
Staffi
Hadn't really thought of that Gareth........
Old Jul 8, 2010 | 06:49 PM
CossieRich's Avatar
CossieRich
Did Someone Mention TUV
Pete,
Quite simply - do not waste you time with a t34!
However, you are your own man and i have had all 3 well known variants of the t34 before moving to the 3071
t34.48 - quick spool up. Cracked exhaust housing around wastegate penny on my stage 3 setup. approx 1.6 bar. Boost tailed off, but sod all lag between gear changes.
t34.55 - not sure why i bothered with it tbh. I listened to rainbird and while he was in fact correct about it being better than the 48 for top end power it was virtually the same as the 48. Same spool up from memory, no lag between gear changes and slightyl better puff higher up the rev range.
t34.63 - was expecting the worst as every expert *cough* out there says laggy as fuck, undriveable, would piss me off blah blah. UTTER horse shit. Slim was correct as per. By far the best exhaust housing on a t34. Ok slightly longer to spool but peaked at 2.5 bar and holding 2bar (maybe a smidge under) to approx 6700 rpm. Came in with a huge shove in the back and i wish i hadn't spent £300 of my hard earnt on the 55 but never mind.
If you must have a t34 get the 63 housing. But if you dont have to get a t34 get a 3071, some bigger injectors and away you go. Forget t34's and t38's. Yesterday's news imo.
Old Jul 8, 2010 | 09:11 PM
Staffi's Avatar
Staffi
Rich,
Good reply that fella and i appreciate what you're saying on the 3071, thing is though dude, i have NO headwork, Standard Cams, 205 block which imo would be ok etc etc, so i'd NOT be making the most of the 3071 capabilities, yes i know folks will say running a 3071 @ 400-420 is SO safe WHY run a 34.63 @ 2.4 bar and have it DIE maybe?? it's a hard one Rich and i know where you're coming from mate AND i have thought about the 3071 too..
FOOKING COSSIES..........
