cooling!!!!!!!!!!!
Old Jul 4, 2010 | 05:13 PM
gtit's Avatar
gtit
Smile cooling!!!!!!!!!!!
how on earth do you keep yours cool after 2 years of work mines finally got roaded yday!!!
i think the bigest problem lies with the frontmount and the fact am using a standard fan?
should i buy 2 9" fans or one big one?
my manifolds wrapd downpipe wrapd, elbow and turbo was but has bn removed should i splash out on a ( turbo jacket)??
is it wise to throw the thermostat away?
any help would be apreciated cheers
Old Jul 4, 2010 | 06:01 PM
gtit's Avatar
gtit
help please i want to get my rs owt agen soon
Old Jul 4, 2010 | 06:06 PM
nigel b's Avatar
nigel b
im using 1 large fan,i think its 12" heavy duty version
Old Jul 4, 2010 | 06:22 PM
gtit's Avatar
gtit
think i could squeze a 16"?
Old Jul 4, 2010 | 06:27 PM
gtit's Avatar
gtit
if some folk use twin 10s would reckon so, is 2 better than 1 tho?
Old Jul 4, 2010 | 07:02 PM
studabear's Avatar
studabear
should i buy 2 9" fans or one big one? maybe 2 fans, fit a new live feed with a relay to give them maximum power
my manifolds wrapd downpipe wrapd, elbow and turbo was but has bn removed should i splash out on a ( turbo jacket)?? no don't get a turbo jacket
is it wise to throw the thermostat away? no the thermostat is there for a reason, make sure yours is working, some suppliers do a lower temp opening item
Is your radiator in good order, with correct anti freeze mixture
google a product called wetter water or water wetter
and is your water pump in good order
Old Jul 4, 2010 | 08:07 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If it's hot when your driving along your fans have nothing to do with it!
Old Jul 4, 2010 | 08:19 PM
XR2's Avatar
XR2
Mounting bigger fans don't cure a cooling problem.
Make sure your rad, the water pump, the thermostate are in a good condition. Check the antifreeze. AND most important: Check how your engine's running. When it's too lean, it also will be getting hot!
I'd recommend:
1. Check management / fuelling
2. Use a new (maybe alloy) rad
3. Use a 82° (RS1600i, maybe Cosworth and FRP also?) thermostate
4. Use a new water pump
5. Get rid of the standard oil cooler, get a new oil/air one!
Old Jul 4, 2010 | 09:36 PM
dave_s2_rst's Avatar
dave_s2_rst
thermostat and msd fan switch! mine made a huge difference in engine temps, needle sits between M-R on the guage and thats in traffic!
Old Jul 4, 2010 | 09:49 PM
orionmojo's Avatar
orionmojo
i run an unvented bonnet, and switching to an alloy header tank helped loads. the alloy dissipates heat better than plastic i suppose.
Old Jul 5, 2010 | 12:50 PM
Puss2's Avatar
Puss2
Formerly know as Puss
I put a MSD fan switch in the other day which has helped mine
Chas
Oct 5, 2015 07:13 PM
`spotty
Sep 25, 2015 11:41 PM
coscor86
Sep 20, 2015 01:21 PM
rogerxr3i
Sep 13, 2015 06:56 PM
Si B
Sep 12, 2015 06:49 AM
