82deg thermo and msd fan switch
Old Jul 4, 2010 | 11:16 AM
dave_s2_rst's Avatar
dave_s2_rst
Default 82deg thermo and msd fan switch
Hi all,
Just a quick one on this, I've fitted the above and the fan now kicks in when the needle hits "M" but doesn't appear to want to switch off. Haven't gone out for a run in it yet.
When timed (at idle), the fan was on for 10minutes not sure how long they would have continued as I switch the car off. The fan does not kick in when started only once it hits the "M". I know its not a major issue as running RSTs' cool is a rarity, but my concern is will it draw lots of current just being on like that?
anyone else running the switch experience the same?
I will update once ive been on a run
Dave
Old Jul 4, 2010 | 02:19 PM
tasos77's Avatar
tasos77
rs turbo from Greece...
I fitted mine last week. My fans klicks when tmp gauge hits the ''M'', when the car is at idle. but after 10-20 sec they stop working.. But i have 3 spal fans, 2 blowing beetwen I/C and rad, and one behind the rad shacking...
Old Jul 4, 2010 | 05:33 PM
Micky's Avatar
Micky
I think its because the MSD fan switch turns the fans on at a lower temp,so I'd guess your fan will spend alot more time running.I would'nt worry about it,should help stop the car boiling over in traffic.Have you asked MSD at what temp their switch is set to turn on the fan??
Old Jul 5, 2010 | 12:55 PM
Puss2's Avatar
Puss2
Formerly know as Puss
I fitted mine the other day at they switched off at approx 90 degrees
Old Jul 5, 2010 | 01:42 PM
dave_s2_rst
where abouts it 90deg on the guauge?
cheers
Old Jul 5, 2010 | 02:55 PM
morph's Avatar
morph
never really had an rs turbo boiling over in traffic except when the raditor was fckued and even then it was never bad once you start moving it was ok.
Old Jul 5, 2010 | 08:21 PM
Puss2's Avatar
Puss2
cheers
Dont know im afraid as i have a stack gauge
Old Jul 6, 2010 | 12:05 AM
10th_racer's Avatar
10th_racer
i'v got an 82 degree stat and msd fan switch in mine with 2 spal fans on the front of the intercooler, my fans come on at just over 90 degrees and go back off just below 90 without a problem.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
rsguy
44
Sep 29, 2015 03:29 PM
cossie330
Sep 27, 2015 04:13 PM
wheelwizardrefurbs
Sep 18, 2015 08:59 PM
xrmalin
Sep 13, 2015 06:52 PM
