actuator
Old Jul 1, 2010 | 10:08 PM
1strst's Avatar
1strst
Default actuator
i will hope fully get my -31 tommorow so i will be fitting it on sat does anyone have a rough idea of what pre load to set on the arm to get 10 psi half a hole like normal or full hole?
Old Jul 1, 2010 | 11:40 PM
mark2's Avatar
mark2
hi
i would not just set the load without a good quality boost guage as just setting it like someone elses is a no no use a guage if you dont have one fit one it will tell if somethink goes wrong when driving also
but failing that go to a tuner and have it set at 10psi
mark
Old Jul 1, 2010 | 11:47 PM
conor.rst's Avatar
conor.rst
What do you mean by half a hole or a whole hole ?
Old Jul 1, 2010 | 11:48 PM
mercgrey's Avatar
mercgrey
half a hole is around 7psi so maybe harf a turn to a turn shorter! at a guess, but as above id definatly get a gauge or at least borrow one to set iy up
Old Jul 1, 2010 | 11:49 PM
mercgrey's Avatar
mercgrey
the actuator eyelet/rodend is half the hole over the wastegate arm
Old Jul 2, 2010 | 12:05 AM
conor.rst's Avatar
conor.rst
Oh i see
Old Jul 2, 2010 | 08:52 AM
project rs's Avatar
project rs
if you've got a tyre pump then use that to set up 10psi on actuator arm prior to fitting it then you know what pre load you've got, and to do that you need to follow pipe that is attached to the actuator to the amal valve, remove it from amal and attach it to your tyre pump and opertate it till it reads 10psi and you'll see your act rod moving, at this point adjust it so it slips on penny arm easily then release the pressure and then it'll take 10 psi now to open waste gate penny there fore giving 10psi of preload/boost but as above have a guage in it to double check as depending on intercooler etc you may get some boost drop
Old Jul 2, 2010 | 09:18 AM
1strst's Avatar
1strst
i will do it as you describe and yes i should have put ive got a gauge to double check thanks to all
JK12
33
Apr 26, 2021 12:09 PM
steve.rst
Mar 15, 2016 08:01 AM
A.t.p
Sep 29, 2015 05:04 PM
rs_jim
Sep 19, 2015 08:41 PM
wheelwizardrefurbs
Sep 18, 2015 02:39 PM
