stage 3 advice please?
Old Jul 1, 2010 | 06:33 PM
mgbrs's Avatar
mgbrs
Post stage 3 advice please?
right guys i,ve got sum spare cash and, want know the best way/place to take my stage 1 2wd saph for a stage 3 conversion, think its between NMS motorsport, or motorsport developments?? the engine is really healthy and has been reliable for the 2 years i have had the car, been serviced at moorland classic cars near leek.
its on a standard T3, but has a 4x4 intercooler, standard airbox.
i know its a common topic, but just want get it right.
any advice much appreciated
Old Jul 1, 2010 | 06:40 PM
martysmartie's Avatar
martysmartie
You will need another chip, 3 BAR MAP sensor, and Siemens 55LB injectors, or you could go for Bosch 803's (Dark Green injectors) but there not avaliable new anymore and an uprated breather kit.
You could keep the T3 or change to a T34.
As to who you go to there both reputable companys so choice is yours.
Martin
Old Jul 1, 2010 | 06:46 PM
mgbrs's Avatar
mgbrs
cheers pal, think i,ll go with nms, its that little bit closer to me!
Old Jul 1, 2010 | 10:06 PM
cossiegreg1's Avatar
cossiegreg1
go to Nms. trust me.
Old Jul 1, 2010 | 10:10 PM
Staffi's Avatar
Staffi
The Spec you have there is the Spec i have now more or less AND i'd say give Karl @ NMS a call and go and have their Gunship live map done, trust me, it'll blow you away..
Old Jul 1, 2010 | 10:47 PM
LHD220Turbo's Avatar
LHD220Turbo
depends on what power you want, & how much you've got to spend?
proper stage 3 is:
t34 turbo
rs500 style intercooler
siemens blacks 55lbs or greens
3 map bar sensor
-31 actuator
decent breather
chip
considering your in stoke on trent, you've got one of the best around on your doorstep in tony @ turbosystems
if not then msd & NMS are brilliant, you wont go wrong with any 3 of them.
Old Jul 2, 2010 | 06:15 AM
benporter's Avatar
benporter
If you are keeping the t3 then gunship is the only one to get
Old Jul 2, 2010 | 07:35 AM
The 4wd i/cooler may struggle a bit on hot days, I'd seriously consider fitting a RS500 type.
Old Jul 2, 2010 | 08:09 AM
Staffi's Avatar
Staffi
If you haven't already, seriuosly consider, or put some money aside for a Clutch, because the torque you'll be getting when you do upgrade will KILL a standard one @ some point...Head Gasket too.........
Old Jul 2, 2010 | 08:17 AM
I had the std (ap) borg and beck, no issues with slipping but 4 out of the 6 springs in the friction plate rattle like f**k, so wouldn't use another!!
Old Jul 2, 2010 | 08:59 AM
Staffi's Avatar
Staffi
My standard clutch shat itslef just @ 280/291ft/lb Tab..............
Old Jul 2, 2010 | 09:36 AM
riks2rst's Avatar
riks2rst
Ive been thinking about the gunship live map, any idea what bhp and torque figures you get with this conversion? also how much do nms charge?
Cheers,Rick
Old Jul 2, 2010 | 01:30 PM
I think it's luck of the draw tbh, first time ever I've had a friction plate rattle so bad, the springs "slots" are very worn it rattles when you shake it, so X by 6000rpm!!, serious noise it was so embarrasing, rattled as son as you went over around 3000rpm.
Old Jul 2, 2010 | 02:40 PM
Staffi's Avatar
Staffi
Cheers,Rick
Live map will cost between Ł400-500
What mods do you have on your car now buddy?
As for power, around 310-320bhp and can be upto 340-350ft/lb like mine...
My spec is, TT Stage 2 T3 with 360 Bearing, Bailey Breather, 3bar -31 Actuator- 803 Injects, Group A HG and AP Paddle Clutch and 4x4 cooler
Old Jul 2, 2010 | 03:06 PM
riks2rst's Avatar
riks2rst
[quote=Pete 3dr;4980204]Live map will cost between Ł400-500
At the moment i just have stage one chip with t3 but do have some dark green injectors and pro alloy cooler and 3 bar map sensor to go on
Any ideas what power i would get from a live map with these mods?
Cheers,Rick
Old Jul 2, 2010 | 05:55 PM
Staffi's Avatar
Staffi
[quote=riks2rst;4980240]
Cheers,Rick
As said, T3 can probably push 320-330bhp max, as for torque mapped correctly, i'd say realisticly 350ish, mine made 354ft/lb but i see Ash has just made 390ft/lb on his T3....
Old Jul 2, 2010 | 07:37 PM
gavk's Avatar
gavk
I have had my 3dr stage 3'd by tony @ turbosystems, live remapped and now goes like stink. Would highly recommend Tony!!!
Old Jul 5, 2010 | 05:24 PM
mgbrs's Avatar
mgbrs
cheers fellas, iam going give nms a bell this week about the gunship live map , and wheres the best/cheapest place get a ap racing, organic clutch from.....burton power??
Old Jul 5, 2010 | 05:52 PM
The Crocodile Hunter's Avatar
Mine is running stage 3 with a T3 and i have been having big clutch problems
Put a new genuine ford in, no good
Tried another and skimmed flywheel, no good
Then tried an ap 6 paddle centre with a new standard cover, felt better but still slipped
I didnt want to go for the ap cover as i wanted to stay away from the heavy pedal, but was forced to in the end using the paddle centre and its fine
Went to burtons and it was Ł240 odd just for the cover, think you can get the paddle kit for about Ł370 ish, after my troubles thats all i would go for?
Old Jul 5, 2010 | 06:19 PM
Staffi's Avatar
Staffi
You'll NOT be disappointed fella........
Old Jul 5, 2010 | 06:43 PM
Turbosystems's Avatar
Turbosystems
Super Moderator
if your running a standard t3 just have the greens 3 bar and a chip fitted and set up no need for live mapping with your spec
Old Jul 5, 2010 | 06:49 PM
scottyrs's Avatar
scottyrs
DURHAM RSOC
nms all the way mate mine was there in january with the previous owner and i cant get enough of mine!!
mk3ste
Oct 17, 2021 10:09 AM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
rsguy
44
Sep 29, 2015 03:29 PM
Marv888
Sep 26, 2015 03:44 PM
