help !!! need a guide on how to strip a 2wd diff !!
formerly beefy-rst-2
as title folks , got to send mark at mk motorsport my diff casing and cover ,
obv it need stripping down before hand , but ive never stripped one ,
so anyone got a few refrence pics, or know of a step by step guide i can follow
beef
beef
its quite simple
case cover off, tap off the 2 circlips holding the output shafts in place, pull them out, then remove the locking tabs, then c spanner or thin flat bar and wind out the holding rings and out pops the diff, I would leave the pinion in place as that more awkward to do.
lol i dont need to ask anymore questions.
the reason why the diff needed to be stripped,would depend on the advise given.i have rebuilt quite a few cossy diffs.
if its just because mk asked for it,then carry on.
ahh cushty mate ,
no problems with the diff , its in fine working order, think mark just wants to double check the mounts with my casing ,
and obv more manageable to handle and post when the internals are removed
also going to have him weld in a fitting for a -6 areoquip fitting for a breather ,
but he dnt know thta just yet lol
beef
beef
no problem.
you will need a dial gauge to put it all back together again, there is a good explanation in one of the online Ford rally prep books on how to rebuild the diff.
Mate of mine put one back together for me and set it up by sight, just watching the way the roller bearings moved in the cage as he adjusted the winders, and it was spot on when re fitted, but thats from years of experience.
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 3, 2015 04:08 PM
