t3 turbo
ive been looking on ebay for a turbo and a guy called turbo revs does a t3/t4 turbo for £200 just wondered if its any good or any one knows anyhting about them.
Turborevs T3/T4 turbochargers consisting of a T3 turbine section, (standard, Stage II or Stage III trim) and a T4 compressor section (T04B trim or T04E trim). The T3/T4 offers the low inertia and fast boost response of the light weight T3 turbine wheel and the high airflow characteristics of the T4 compressor family, making the T3/T4 the turbo of choice for high performance “import” applications
Whats included?
T3/T4 TURBO AS PICTURED
Stage-3 Turbo T3/T4
Compressor Wheel / Housing A/R Ratio:
Inlet (mm): 50.5; Outlet(mm): 76; Trim (in/out x 100): 55; A/R: 0.5
Turbine Wheel / Housing A/R Ratio:
Inlet (mm): 65.5; Outlet(mm): 55.9; Trim (in/out x 100): 73; A/R: 0.63
Stage-3 Turbo T3/T4
CNC Machined Flanges 4Bolt Designed fit most After market Mainfold
Internal Wastegate supports upto 14psi
Turbo supports applications upto 350BHP
JK12
33
Apr 26, 2021 12:09 PM
