my rs wont boost ?
Old Jun 28, 2010 | 10:42 PM
cabrio boy's Avatar
cabrio boy
Default my rs wont boost ?
right got an rs from a mate because he is fed up with it so thought i would add it too my collection , it has a big boost problem engine is 100% no rattles smoke anything as is fresh . now guy was under the impression that his turbo had let go and thats why he wasnt boosting well i got my hands on it swapped the turbo off of another of my cars togethor with all samcos and vacume pipes as well as a bleed valve all of which worked 100% on my other car now after replacing everything still no boost if i nail it on load in 3rd and 4th will boost to 2 psi but no more 1st gear and 2nd boost gauge just reads 0 any ideas people as it has stumped me ??? wonder ed about inlet manifold or metering head as that is all that is left on the car ? lol
any opinions please ???????
many thanks in advance
Old Jun 28, 2010 | 10:47 PM
Chopshop85's Avatar
Chopshop85
Have you tried changing the actuator?
Old Jun 28, 2010 | 10:48 PM
botters's Avatar
botters
competant bodger
knackered boost guage maybe?
Old Jun 28, 2010 | 10:57 PM
cabrio boy's Avatar
cabrio boy
it wont boost ther is no boost if you give it a hiding then you get the smallist noise so somewhere there is a boost leak actator is new and set up all came from my other car which boosts up fine now could this be from the metering head or inlet manifold anyone else had this happen as ive owned a fair few and never come across it .
Old Jun 28, 2010 | 10:59 PM
cabrio boy's Avatar
cabrio boy
as well ive pulled the pipe off to run unlimited boost still doesnt boost any different ??? boost gauge is a ford racing one again off of another car where it works fine so trust that too
botters's Avatar
botters
competant bodger
ive had boost guages leak before, never enough to completly lose all boost tho
Old Jun 28, 2010 | 11:00 PM
cabrio boy's Avatar
cabrio boy
use 2 differnet boost gauges tried unplumping everything so vacume is just to the ecu alone still nothing
Old Jun 28, 2010 | 11:01 PM
cabrio boy's Avatar
cabrio boy
i wondered if an inlet manifold gasket could be leaking and causing it ?
Old Jun 28, 2010 | 11:06 PM
botters's Avatar
botters
competant bodger
that would cause a high idle speed also, its worth checking tho get some wd40, easystart or brake cleaner and spray around the inlet while running, if the revs alter then you have an air leak
Old Jun 28, 2010 | 11:08 PM
cabrio boy's Avatar
cabrio boy
tried that nothing :O( spoke to simon from at a1 rally sport he was stumped to its an odd one need to get the system pressure tested , but im sure i can find out what it is as the mfi system is so easy
Old Jun 28, 2010 | 11:21 PM
botters's Avatar
botters
competant bodger
post what you find would be interesting to see the outcome of this one
Old Jun 29, 2010 | 06:22 PM
cabrio boy's Avatar
cabrio boy
bump ???
Old Jun 29, 2010 | 06:26 PM
mr_joe0606's Avatar
mr_joe0606
duno if this is corect just what i have heard or miss heard. maybe the knock sensor is faulty?
joe
Old Jun 29, 2010 | 06:33 PM
DNA Tuner's Avatar
DNA Tuner
have you tried disconnecting the amal valve, and running the pressure feed from the turbo inlet direct to the actuator?
Old Jun 29, 2010 | 07:19 PM
PETEDUDE007's Avatar
PETEDUDE007
which pipe did u pull off!?
Old Jun 29, 2010 | 09:55 PM
cabrio boy's Avatar
cabrio boy
pulled off the bleed valve which bypasses the amal valve so that cannot be at fault :O/
how can i test the knock sensor ???
Old Jun 29, 2010 | 10:15 PM
Chopshop85's Avatar
Chopshop85
unscrew it and cable tie it to a hose or something that wont vibrate.
Old Jun 29, 2010 | 10:26 PM
juffer's Avatar
juffer
i had the exact problem a few years ago. it was the wastegate "penny" in the elbow had fallen off
Old Jun 30, 2010 | 09:26 PM
cabrio boy's Avatar
cabrio boy
ive change the complete turbo overfrommy other car which is a perfect runner and runs 14psi :O(
Old Jun 30, 2010 | 09:32 PM
mattseries2's Avatar
mattseries2
I had the same sort of problem only weeks ago... found out to the the actuator was holding the wastegate open. When its off boost the actuator should be holding the wastegate (penny) shut, if it not its letting the boost out, thus no boost
Try it mate, i had this problem for ages and was a simple fix.
Old Jun 30, 2010 | 09:38 PM
cabrio boy's Avatar
cabrio boy
mmmmmmmm il have a look tomorrow just my actuator was on the other car and was fine swapped it over as a whole unit why would it be different from just swapping cars mmmmmmmmmm something to look at though ,
as for the knock sensor what does it do ?
Old Jul 1, 2010 | 01:01 AM
Chopshop85's Avatar
Chopshop85
senses knocking lol If you get detonation in the chambers its does something to rectify. I dont know what it does though lol you'll have to ask someone else.
Basically a safety meassure. I had a faulty one so when my car was on the dyno I got a very squiggly line where the knock sensor couldn't make its mind up.
Old Jul 1, 2010 | 06:10 PM
cabrio boy's Avatar
cabrio boy
ah cool would it stop it boosting altogether though ?
Old Jul 2, 2010 | 09:37 PM
cabrio boy's Avatar
cabrio boy
right took another knock sensor of my other engine still no diffrent whats next any ideas ? is to much to ask that i want boost lol
Old Jul 2, 2010 | 09:56 PM
mr_joe0606's Avatar
mr_joe0606
Whats the intercooler like any holes in it? Is there any pipes missing from inlet? How does the car run?
Joe
Old Jul 2, 2010 | 11:18 PM
BRAM's Avatar
BRAM
I would check the intercooler as it seems you have checked everything else might have a hole in!!!!!!!
Good luck
Old Jul 3, 2010 | 08:55 AM
JamboRS's Avatar
JamboRS
focus rs 1672
id do a compression test
Old Jul 3, 2010 | 12:40 PM
DazC's Avatar
DazC
That included the elbow with the wastegate arm and penny?
Has it got a dump valve on it? If so, remove it and block the hole up.
Old Jul 5, 2010 | 04:20 PM
scoooby slayer's Avatar
scoooby slayer
if it had that big a boost leak youd hear it id of thought. ive got a fitting to pressurise the system at the yard mate
does it run ok aside from no boost ?
Old Jul 6, 2010 | 10:51 PM
cabrio boy's Avatar
cabrio boy
car runs sweet as just no boost lol il have to pop up dude !!
Old Jul 7, 2010 | 01:40 PM
white2lsr's Avatar
white2lsr
Are you sure its not really an XR3i?
Old Jul 7, 2010 | 03:03 PM
mattseries2
Lmao!
Old Jul 7, 2010 | 08:26 PM
scoooby slayer
yes mate ring me and we sort it out, bring it over itl only take a few mins to do. ive got a plug with a gauge in just gotta find it.
Old Jul 13, 2010 | 11:08 PM
rambo84's Avatar
rambo84
did you find out problem m8, got the same problem but just thought my turbo gave up on me, dont want to buy turbo if it aint that lol.
Old Jul 19, 2010 | 07:56 PM
cabrio boy's Avatar
cabrio boy
na still in the workshop have had my white turbo out to the shows so have just left it sitting there this week il get on the case and have another play
timsrs
Nov 13, 2018 11:48 AM
Nov 1, 2015 06:53 PM
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
oilman
Trader Parts for Sale.
Sep 23, 2015 07:32 PM
