the safe limit on a -31 is 8-10psi, so adjust the rod till you achieve this then the rest of the boost pressure will need to come from a bleed valve/boost controller.
from the posts ive put up you seem to be on most of them karlos and you seem to know your stuff and have given good advice so i thankyou for that.But now i want to pick a bit more do you have a link to timing its a standard cam and pulley many thanks again
ok got a timing light so how do i exactly go about it set the crank to tdc at no1 and the cam to the timing mark as per haynes.Then how do i get it to 12 deg adjusting thedizzy?
Yes mate stick the light on No.1 plug lead, remove vacuum hose from ECU (block with finger), car should idle, twist dizzy to adjust timing.
Obviously you need to put a bit of white paint on the crank pulley cut away, and the 12deg mark on the bottom cam belt cover first
IIRC 0 is the biggest mark and then each mark is 4 deg, so it's the 3rd one to the left, but check in your haynes manual as I've not done it for a looooong time! lol
