whats the better aux belt set up on a cossie? twin belt or multi rib?
Old Jun 28, 2010 | 06:31 PM
M K's Avatar
M K
Default whats the better aux belt set up on a cossie? twin belt or multi rib?
i see there is 2 different set ups of aux belts that the cossies came with on various models etc
a 2 belt system for water pump and power steering etc and a multi rib single belt?
whats the better option?
its for a 200block 4x4 engine but im buying all new alloys puuly's so can choose what to run
thanks Marc
Old Jun 28, 2010 | 06:40 PM
ive heard a few people say that the tensioners on the ribbed belts nack up and they are dear to replace.
Old Jun 28, 2010 | 07:14 PM
If I had a choice even though I'm on single/twin belt I'd go for multi ribbed everytime.
Old Jun 28, 2010 | 09:23 PM
DazC's Avatar
DazC
Poly V (multi V) belt is better all day long.
Better grip and longer life.
Old Jun 28, 2010 | 10:21 PM
stu21t's Avatar
stu21t
i thought the reason for the twin belt setup meant that it couldnt slip? as both would have to slip at the same time
no idea which is better tho
Old Jun 28, 2010 | 10:33 PM
andy escos's Avatar
andy escos
i think i remember rod mentioning that the twin belt set up is no good at high rpm & he is running the multi groove belt system
Old Jun 29, 2010 | 02:43 AM
Ginge !'s Avatar
Ginge !
just finding my feet
there is a reason why cars dont generally have crappy toothed belts on em anymore...... your telling me you dont miss the "SQUEEEEEEEKKKKKKKKKKKK" in the rain pulling out of corners that used to happen,,,,,, then SNAP
poly V is def the best option, more grip and longer life too
Old Jun 29, 2010 | 04:20 AM
i dont know mind ginge ive heard a lot of the v belts squeak too. It must be better cause ford wouldnt of changed it on the cossies.
Old Jun 29, 2010 | 07:27 AM
Csm's Avatar
Csm
Twin belts were just a pain in the arse
Old Jun 29, 2010 | 07:52 AM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
Yes thats correct at sustained rpm ( 8k+) the Power Steering belt would turn over & hit the cooling belt, we ran without the outer belt on Topspeed runs.
Old Jun 29, 2010 | 08:02 AM
JamesH's Avatar
JamesH
What do you have to change to go to the multi groove setup?
Old Jun 29, 2010 | 09:53 AM
Need to change the pulleys, ie crank, alt, water pump, ps pump.
I can't change as my trigger wheel is locked/welded to my crank pulley.
Saying that I've never had any slippage in the wet, but do have to hunt a bit for two belts when replacing them that are the same width, even ones of the same make can vary in width, as most makers actually just buy them in and box them, plus multi seem to last forever as well.
Old Jun 29, 2010 | 12:00 PM
M K's Avatar
M K
Does anyone have pics to compare the two belt styles and
pully's?
Thanks Marc
Old Jul 1, 2010 | 02:39 PM
JamesH's Avatar
JamesH
Tabs, I assume all the pulleys are just a simple swap over, no different bolt hole alignments or anything silly like that?
Or you could get all new anodised pulleys for the 4x4 and put them in a 2wd?
Old Jul 1, 2010 | 06:56 PM
dakar's Avatar
dakar
Transits are on v belts and they all squeak badly
Old Jul 1, 2010 | 08:27 PM
snoopaloopa's Avatar
snoopaloopa
Any belt will squeak if its not tensioned/maintained correctly
Old Jul 1, 2010 | 08:34 PM
wes's Avatar
wes
Here is the small turbo escort setup fitted to my saph, much neater and better than the 2 belt setup:
Old Jul 1, 2010 | 08:57 PM
M K's Avatar
M K
not running power steering wes?
Old Jul 5, 2010 | 12:45 PM
wes's Avatar
wes
The big pulley on the bottom left is the power steering pump. The spare set of grooves on the front of the crank pulley is for an air con pump which i don't run
Old Jul 5, 2010 | 01:36 PM
Gazzonator's Avatar
Gazzonator
Gary Krishna
To change over to the later ribbed type belt, you will need the main bracket that goes on the offside side of the block, tensioner, all the ribbed belt pulleys, and power steering pump pipe (the power steering pumps are on opposite sides). I'm pretty sure the pumps are the same.
Old Sep 16, 2010 | 02:29 PM
M K's Avatar
M K
anybody got a pick of the multi ribbed belt but on an engine with the power steering on the nearside and no air con
thanks
Marc
Old Sep 16, 2010 | 02:45 PM
xr4x4rs's Avatar
xr4x4rs
i dont know if anyones done it but thats how i was going to go on my escos
as far as i know you need a ribbed belt pulley for crank, water pump and alternator, you will also use a 2wd alt bracket and tension it like you would ona twin belt system
the p/s pump would be v belt and need to be spaced out to keep it inline with the front of the crank pulley as this would use the v groove on the crank usually for aircon
Old Sep 16, 2010 | 04:54 PM
BLACKCOS's Avatar
BLACKCOS
i had the later style multi v belt on my facelift cos never had any problems with it.
Old Sep 16, 2010 | 08:02 PM
markk's Avatar
markk
make up the multirib but without that fooking massively heavy bracket - you can still have a manual adjuster on poly v setup.
Old Sep 16, 2010 | 08:12 PM
M K's Avatar
M K
What bracket mark ?
Old Sep 16, 2010 | 08:23 PM
xr4x4rs's Avatar
xr4x4rs
its what i saidm you will use a 2wd alt bracket and tensior bracket, so its a multi ribbed belt but you adjust as if it was a twin belt set up
Old Sep 16, 2010 | 09:37 PM
markk's Avatar
markk
Originally Posted by M K
What bracket mark ?
i reckon you could use one of marks Alloy units as per the 2wd, fit all the std poly v pulleys - you dont have to have auto adjusters - not like your trying to do 2-,40k miles on it without maintenance.
Old Sep 16, 2010 | 10:09 PM
M K's Avatar
M K
Will use all alloy pullys and brackets and Will also be using wrc alt bracket so it mounts at the bottom and swings out at the top so I can fit a bigger better alt
Old Sep 16, 2010 | 10:17 PM
markk's Avatar
markk
do you need more than 90amps to run your car? thats a lot of current pal. dont go over spec for no reason.
if you work out you need it then by all means by a smaller version with the same output
Old Dec 29, 2010 | 03:24 PM
M K's Avatar
M K
Can you get a multi ribbed belt as shown above but one that only goes from crank to water pump to alternator? i will either run the power steering on the other side with a single v belt or i will be running electric power steering so will have no power steering pump or belt
thanks
Marc
Old Dec 29, 2010 | 03:25 PM
M K's Avatar
M K
I looked into it Markk and no i do not need that much ampage so i will be running a 2wd alternator/bracket/tensioner set up
Plus the cost of a grp a alternator bracket is ridiculous!
Old Dec 29, 2010 | 03:32 PM
focus 4x4's Avatar
focus 4x4
thanks
Marc
The crank pulley in the picture is a T25 36-1 escort cosworth varient.
Dunno if that helps?
Old Dec 29, 2010 | 03:41 PM
M K's Avatar
M K
what i want is a crank pulley with multi rib on the inside and v belt on the outer side,
Im gonna be getting a billet pully from mk motorsport so im sure he could do this for me with a 36-1 trigger ring on the back.
Just need to know if i can get a multi ribbed belt that just does crank/alt/water pump
Old Dec 29, 2010 | 03:49 PM
GaryHurn's Avatar
GaryHurn
yes you can get any length of belt you like measure it uo and go to a local motorfactors will have one on the shelf, i have had to do a few conversion and have never failed to get a belt
Old Dec 29, 2010 | 04:08 PM
Miller 3's Avatar
Miller 3
Iv just recently dropped off some 4x4 pulleys to Chris of CDF racing Marc, im sure he would do what you want bud.. not to far from us either, infact i pop in there from time to time.
Old Dec 29, 2010 | 07:37 PM
jamie's's Avatar
jamie's
the pas pump is differant(i know cause i need 1 and cant find 1 local for my 4x4)
and the pipes are differant to and need changed when converting from old spec to newer spec
Old Dec 29, 2010 | 07:43 PM
markk's Avatar
markk
all the bling cost lots of money pal ! whether you need it or not is what you need to decide, looking good does not always mean going fast !
as for the belt setup, yes you can get a belt and a pulley, the std 4x4 has both iirc. (just not the 36-1/2)
Old Dec 30, 2010 | 11:09 PM
Miller 3's Avatar
Miller 3
Iv been thinking more and more about getting the multi v belt set up converted to run the 2wd way!
Old Dec 31, 2010 | 08:24 AM
Martin-Hadland's Avatar
Martin-Hadland
1st to 200 without NOS
2wd and 4x4 Pas pumps are the same part.
Old Dec 31, 2010 | 08:27 AM
M K's Avatar
M K
What do you mean with that big heavy fook off tensioner set up?
