dump valve bung question
Old Jan 18, 2005 | 03:15 PM
percybigun's Avatar
percybigun
Twistin me melon man
Default dump valve bung question
i have a RS turbo charge carrier (metal type) on my mondeo, and it has a air sensor thingy (not in use) in the dump valve take-off. i suspect this sensor isnt air tight, so i want to put in a proper bung. is the hole in the charge carrier threaded, if so am i right in thinking a M14 bolt will fit in there?
Old Jan 18, 2005 | 03:58 PM
james_birch's Avatar
james_birch
have you got a picture!
Old Jan 18, 2005 | 04:07 PM
percybigun's Avatar
percybigun
yeah you can see it on the top left here
Old Jan 18, 2005 | 04:13 PM
james_birch
that aint the dump valve take off!
and it must be air tight! other wise it would loose rs trubos there boost! but if you suspect it aint air tight then either stick some sealent on it! or weld sumit into it!
Old Jan 18, 2005 | 04:35 PM
percybigun's Avatar
percybigun
ah ok i will forget it then! i have a slight boost problem (its on a 1.8TD mondeo with front intercooler conversion) so i suspect its either a faulty dawes device boost controller, or a split intercooler pipe (been waiting for weeks for replacement )
Old Jan 18, 2005 | 04:40 PM
james_birch
gotta say you mody looks well nice in them pics on your site!
good work fella!
except one thing! take the dump valve off!
Old Jan 18, 2005 | 04:44 PM
percybigun's Avatar
percybigun
cheers!
the dump valve is more for a bit of a laugh than anything else, not trying to be chav. and its not fake, it is properly plumbed into intercooler ducting. your the first person i have ever known who said its a bad idea! everyone else thinks its well funny to have a DV on this motor - keeps people guessing wondering what under the hood (the zorst blanks out most of the diesely sound, and on full throttle it sounds nothing like a diesel since i got it tuned up)
Old Jan 18, 2005 | 04:51 PM
james_birch
i just hate dump valves! with a passion!
And i heard one on a diesel 306 and i really didnt like it!!
other than that your cars sweet as!
Old Jan 19, 2005 | 01:52 PM
adamS2RST's Avatar
adamS2RST
dv = we all know it!
Neil Clark
21
Oct 1, 2015 07:02 PM
IainRS1700T
Sep 25, 2015 06:44 AM
RS-Rikki
Sep 21, 2015 07:27 AM
rs_jim
Sep 19, 2015 08:41 PM
richierich1986
Sep 18, 2015 03:29 PM
