Bleeding Rs turbo brakes
Old Jun 27, 2010 | 03:47 PM
155lee's Avatar
155lee
Default Bleeding Rs turbo brakes
I have changed the calipers on my s2 and some of the pipes,the pipes were left open for about a week so all the fluid dripped out.I can't get a solid pedal now.it still has the abs hooked up and I'm getting fluid from every corner.any ideas?ta,lee
Old Jun 27, 2010 | 03:48 PM
Madbradz's Avatar
Madbradz
You Tried pressure bleeding?
Old Jun 27, 2010 | 03:57 PM
155lee's Avatar
155lee
No,don't have a pressure bleeder.
Old Jun 27, 2010 | 04:07 PM
blacky.'s Avatar
blacky.
take the abs off its a waste of time on rst it makes the brakes feel dead get rid of it & you will have brakes that actually stop the car
Old Jun 27, 2010 | 04:09 PM
studabear's Avatar
studabear
rear arms need lifting or wheels on ground when bleeding the rears
Old Jun 27, 2010 | 04:12 PM
S1's Avatar
S1
Remember that at the back end you need to bleed the brakes with the suspension on its wheels as the rear load sensing valves will prevent it from bleeding otherewise. Jack the car up, take the wheel off and then lower the car onto an axle stand under the rear swing arm to compress the suspension as it would be when on its wheels.
Old Jun 27, 2010 | 04:13 PM
S1's Avatar
S1
Doh! beat me to it lol.
Old Jun 27, 2010 | 06:58 PM
155lee's Avatar
155lee
I did al that stuff with the rear brakes and I just want them bled do I can get it mot d this week so is there any trick I'm missing?jacking the rear up high,pressure bleeding,having the front wheels turning????
Old Jun 27, 2010 | 08:34 PM
Lloyd's Avatar
Lloyd
escort mk4 cossy 4x4
it might be because the brake pads need bedding in.
Old Jun 28, 2010 | 05:29 PM
155lee's Avatar
155lee
its not the pads,theres just no brake pedal.when you pump the brakes the pedal gets firmer but when you release the pedal it goes soft.theres air somewhere,maybe the abs pumps?if so how do i get that out??
Old Jun 28, 2010 | 06:41 PM
mattseries2's Avatar
mattseries2
Get rid of the ABS mate, best thing you can do to the standard setup
SmudgerByName
52
Jul 28, 2016 06:14 PM
Matt Baxter
Sep 16, 2015 08:30 PM
blackbeautyzetec
Aug 29, 2015 02:11 PM
Ben26
Aug 27, 2015 08:56 PM
jay030787
Aug 17, 2015 06:16 PM
