Knocking noice from the rear ?
Old Jun 27, 2010 | 12:36 PM
2wd's Avatar
2wd
Default Knocking noice from the rear ?
Hi does anyone have an idea about this ... Almost evry time when I accelerate and when I Let go of the throttle there comes a knocking noice from the rear...? I can make it do the knocking noice if I tab the throttle on/off ?
Please advice ?
Old Jun 27, 2010 | 12:39 PM
Mark_'s Avatar
Mark_
rear beam bushes or prop shaft links maybe?
Old Jun 27, 2010 | 01:21 PM
As said check beam bushes, inner and outer arm bushes, and also the rear fiff mount, it's not unusual to have a bit of a clonk on well used diffs as this is play, had it esp on me auto's for some odd reason.
Old Jun 27, 2010 | 01:38 PM
2wd's Avatar
2wd
Hi ...ok .. the big bushes, one in each side of the beam is new powerflex, rear ARB bushes are new powerflex, diff hanger is new poly type and there is ok space between ARB and mount.
Diff is "new" uprated (uprated visco and planet gears) one from CTS done about 2500 km .. but I have mixed feelings about the diff as I have had problems with it and it has been at CTS twice as it is noicy (more than the old std one +300K km) .. and now the third one is leaking a little from each side and still a bit noicy :-(
Trailing arm bushes are OE type and while I have had the car not been changed as I have been told not to use poly there ??
Driveshaft has done MANY miles and there is some play in them (seems to be at the CV joints) ?
the probshaft has done MANY miles but seems ok
Old Jul 11, 2010 | 02:27 PM
2wd's Avatar
2wd
upp
Old Jul 15, 2010 | 07:32 PM
2wd's Avatar
2wd
Hi...found these companies who do CV joints ... Driveshaftuk, GGR, Reco-prop, Davemacprops and Prolinx.
can anyone recommend one of the above ??
Old Jul 16, 2010 | 07:22 AM
RECO-PROP used them myself several times, ace company.
Old Jul 16, 2010 | 01:22 PM
2wd's Avatar
2wd
Ok...I'll try to get a quote from them ... thanks
Old Jul 31, 2010 | 02:56 PM
2wd's Avatar
2wd
hi ... Do you know if they are still around ?? As I've been mailing them a couple of times, but got no reply ??
Old Sep 6, 2010 | 08:36 PM
2wd's Avatar
2wd
upp
Old Sep 8, 2010 | 09:04 AM
kong's Avatar
kong
try the exhaust
Old Sep 9, 2010 | 01:59 PM
2wd's Avatar
2wd
Originally Posted by kong
try the exhaust
Exhaust is ok .. but thanks
155lee
Sep 6, 2016 11:10 AM
S3an
Sep 26, 2015 11:39 PM
S3an
13
Sep 13, 2015 10:01 AM
The Enigma
Sep 12, 2015 10:12 PM
cossirob
Sep 3, 2015 09:17 PM
