Tesco momentum 99 petrol
Old Jun 27, 2010 | 09:21 AM
COSSY DALE's Avatar
COSSY DALE
msd tooned 380+ bhp
Default Tesco momentum 99 petrol
have always run the cossie on shell v power in the time i have had the car over 7 years now,but heard mixed views on the tesco 99 ron fuel some good/some bad.
so i thought id give it a trial run to see how the cossie ran off it??
for some reason the cossie doesnt like cold starting off this fuel coughs & splutters a lot off it & finds it hard to find a decent idle,but once up to temp is fine & then idles as good as when on v power.
on boost there does seem to be quite a difference in the way the boost kicks in & power compared to v power(as in more) & have also noticed the exhaust tone has got a lot louder also making me think there is a bit more power being produced somewhere??
quit impressed with its performance,just dont like the cold starting side of it & the fuel economy side of things seems to be less than v power
just wondering if anyone else has tryed it & what did u think of it??,did anyone else have cold start issues off running the tesco momentum fuel????
Old Jun 27, 2010 | 09:27 AM
blacky.'s Avatar
blacky.
wenny runs his mk3 on tesco 99 & the nail ran on it when i had it & everyone knows how well them two cosworth power'd cars went
as they were mapped on it they had no issues with cold start
Old Jun 27, 2010 | 09:37 AM
GaryHurn's Avatar
GaryHurn
my nova was mapped on tesco 99 i have ran it on vpower when i cant get to tesco but have not noticed any noticeable difference between the two!! cold start on either is fine (same map)
this is a c20let not a yb
Old Jun 27, 2010 | 09:48 AM
opposite lock's Avatar
opposite lock
i posted up about this fuel the other day ,it gave mine a significant difference in mid range torque , interesting what you say about the cold start idle never thought about that
Old Jun 27, 2010 | 09:50 AM
Tev's Avatar
Tev
i use tescos 99 ron as its my clossest petrol station, my car was set up at msd on shell n i can honistly say i cant really tell the difference, i kinda wonder if people see a difference because they want to see a difference,
Old Jun 27, 2010 | 10:15 AM
opposite lock
i can definately say in my cossie the midrange is improved enough to notice it (smoother) but top end seems the same imo .
Old Jun 27, 2010 | 10:18 AM
retro d's Avatar
retro d
I use Tesco 99 ron and it runs fine but does have a little idle issue when cold but only for 10 secs or so.
Im going to stick with the v power now as im getting it setup on the rollers this week.
Old Jun 27, 2010 | 10:31 AM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
its 1 octain different! to be honnest its in your head id say lol
Old Jun 27, 2010 | 11:36 AM
I did some runs on tesco 99, and also V power, there is a difference, more in smoothness, tesco being better, and also a slight difference in mid range, better on tesco, but top end better on v power, I'd be happy using either, one is a 10 mile drive the other a 15 mile drive each way!!
Haven't noticed any starting or cold idling issues on either, even with running no iscv, winters day still start no probs, just hold for 10-15 secs.
Old Jun 27, 2010 | 12:47 PM
COCHYN's Avatar
COCHYN
No issues with Tesco 99 in mine either, I think I get more MPG on it...probably because its cheaper than the oposition
Old Jun 27, 2010 | 01:05 PM
furry's Avatar
furry
DECODING JIBBA JABBA!!
My old M3 used to detonate on v power but ran so much smoother and quicker on tesco's 99
Certainly a noticeable difference on my ocy vrs
Old Jun 27, 2010 | 01:33 PM
ASHCOSSIE's Avatar
ASHCOSSIE
i run it and cant fault it
Old Jun 27, 2010 | 02:11 PM
opposite lock
its definately not in my head , in my car (1 bar boost) its noticeable enough to mention about it . would think with higher boost and power levels its probably harder to see/feel a difference.
If V-power went to 100 ron i,m sure you,d be tempted ??!!
Old Jun 27, 2010 | 02:16 PM
ajamesc's Avatar
ajamesc
Mine is mapped on v power i do use the 99 a lot as tesco is close to my work so i sometimes stop there when i use the car but myself i carnt notice any difference may be just me But i do wish they sold the bp 102 octain fuel in basingstoke i think id feel that!
Old Jun 27, 2010 | 02:29 PM
Ginger Will's Avatar
Ginger Will
What about the diesels? Anyone any preference, i have a 120d and had BP ultimate diesel in and I think it has more midrange than with Asdas!
Old Jun 27, 2010 | 02:44 PM
KSA-Cossie's Avatar
KSA-Cossie
Do tesco show which petrol stations stock it ?
Old Jun 27, 2010 | 02:59 PM
Roosie's Avatar
Roosie
500bhp Cosworth in making
i have had proven results after using Shell and Tescos i could run more advanced on my saxo race engine on Tesco 99 and it made 2bhp over vpower and these tests have been done on several cars in our championship all with identical results.
Old Jun 27, 2010 | 09:56 PM
Moonstone Mo's Avatar
Moonstone Mo
i mainly use tesco 99 ron i dont notice any diffrence in performance etc but seems to pop and bang a little on v power!
Old Jun 27, 2010 | 10:06 PM
Karlos G's Avatar
Karlos G
Balls Deep!
If it idles rough from cold, and seems faster when on boost, then that sounds like it's lean to me.
Old Jun 28, 2010 | 12:13 AM
turbotoaster's Avatar
turbotoaster
which makes sense if the fuel is bumped up in octane by adding ethanol because you need more fuel per afr reading the more ethanol you run
Old Jun 28, 2010 | 04:00 PM
opposite lock
hell yeah i reckon you would , i read an article BP station in Ilford was quoted at about Ł2.50 odd iirc per litre 102 ron , i wouldn,t know if thats a wise choice for the engine tho if its mapped on 98/99
edit- i read it in a magazine few years ago now PF or FF i think
Old Jun 29, 2010 | 02:15 PM
smudger068's Avatar
smudger068
funnily enough, i normally use tesco 99 and last night used v-power because i was about 15-20 mile into the red and my car seems so much flatter up the rpm compared to tesco 99
Old Jun 29, 2010 | 02:34 PM
G2RSR's Avatar
G2RSR
Bodybuilding
From: Cannot be identified by the information given.
V power is 99ron fuel it also states on some of the petrol pumps
remember higher octane fuel burns slower, so if a slightly lower octane fuel is used without you getting any det it could feel faster because it will burn slightly faster giving the same effect as advancing the ignition a couple of degrees
Old Jun 29, 2010 | 04:52 PM
Rod-Tarry's Avatar
Rod-Tarry
Happily retired
You can get more ignition on V-Power which is why i use it. Dont use arse dynos, just old fashion det cans & lots of trial runs. Dont get confused by octane rating its the ignition you can run before det that counts.
timsrs
Nov 13, 2018 11:48 AM
mk1turboestate
Dec 2, 2015 08:31 PM
Brickhouse
Sep 21, 2015 11:00 AM
jc1989rs
Sep 18, 2015 07:05 PM
Rammer46
Sep 18, 2015 08:31 AM
