sierra cosworth - problem with car ???
Old Jun 26, 2010 | 03:06 PM
1971goy's Avatar
1971goy
sierra cosworth
Default sierra cosworth - problem with car ???
i jet washed my engine to find my oil leak, once i started the car to take it for a run to see where oil was coming from it is now idling at 4000 revs and stopping at 4000 revs.
When i take the wire of the idle valve the car runs at 1000 revs but doesn't seem to run properly, seems as if its going to stall or cut out.
I've changed idle valve and it still has the same problem.
Can anyone help me with this?
Old Jun 26, 2010 | 03:11 PM
botters's Avatar
botters
competant bodger
never jetwash an engine mate!!!!! you could possibly have water in one of your loom connections check them one by one
Old Jun 26, 2010 | 03:17 PM
paul16v's Avatar
paul16v
Monte 087
Check your loom plugs & all other connectors especially crank and phase sensors, give them a good blow out with an airline and then wd40 them.
As said never jetwash an engine.
Old Jun 26, 2010 | 08:11 PM
Is it a 2wd saff or 4x4.If its a 4x4 check the 3 plugs on the back of the engine clippped to the black plastic panel.
Old Jun 26, 2010 | 09:21 PM
D16PJM's Avatar
D16PJM
i did the same trying to find an oil leak and turned out i had water in the plug for the crank sensor, also removed and cleaned dizzy cap as it can condonsate if the engine was warm.
Pete
Old Jun 27, 2010 | 10:43 AM
^^ what he said, the first thing I'd do is dry out the dizzy, as it had hot air inside it and got blasted with water the air codenses and forms water droplets on the inside leading to tracking/cross firing, the plugs in theory should be water tight, but as said check these as some are less water tight than others.
Is the oil leak on the nearside of the engine ?, all up the block, if so check carefully the oil pressure warning switch, these leak, and can empty sumps of oil very quickly!!
JoeyBoyden
Jan 4, 2024 02:36 PM
manuel boeckx
13
Oct 3, 2015 02:29 PM
Aug 14, 2015 07:29 AM
martynhomer01
16
Aug 4, 2015 09:55 PM
Old ford
Jul 31, 2015 06:50 AM
