Anyone know who could reset the hood on my e36 cabby?
Old Jun 25, 2010 | 11:18 PM
vaughant's Avatar
vaughant
Default Anyone know who could reset the hood on my e36 cabby?
The cars in for a full repaint in Ferrari red next week but for many years now the hood hasn't worked electrically.I could probably diagnose it myself with the proper equipment but I don't know how readily available it is?I know there's a cable broken to hold the horseshoe down but I don't know what caused it originally,I replaced some arm as that was bent and it worked so far but then I had to pull the emergency lever!!I know loads of you on here have had them so there must be places other than BMW to get them fixed as I think the hoods were a common problem years ago,mines the semi auto version where you flip it up a bit first to remove the tension.I've been using it manually for years with no problem but were trying to put it right now!!!
Old Jun 25, 2010 | 11:39 PM
reisskahn's Avatar
reisskahn
I can't remember properly now but when you pulled the emergency lever you've disengadged the motors in the boot lid
Think you have to click the motors back in and if i remember correctly on the m3's there on the left hand side when you open the boot behind the carpet. They just click/push back in
Then you have to put on ignition and hold the hood switch or something
try this site and just google with (e36 convertible reset)
http://www.eabjr.com/Synchronize-e36...rtible-Top.php
Hope that helps
reiss
Oranoco
41
Feb 11, 2016 01:28 PM
bigryrs
Sep 7, 2015 06:45 PM
fuzzy
Sep 4, 2015 10:11 PM
liam-rst
Aug 10, 2015 08:46 AM
