help rear wishbone polybushes
Currently fitting floflex bushes to my S2, front ok but rears not so easy, so if you can help, will be much appreciated.
On the rear wishbones inner, do you need to remove the metal sleeve before you can fit
the 3 part bush and sleeve.
The outer 2 parts of the bush seem to fit with the sleeve fitted but the larger inner is too large
I have searched past posts and cant seem to find a definitive answer.
I have attached a pic
Hi there buddy,
I have been doing this today! mine never had the metal sleeve??? But already had poly bushes fitted, so im going to go with, yes, remove the sleeve... however some one who has done this before may say something else.
Rob,
Rob,
Cut the centre out with the grinder, leave a lip each side, then take a big screw driver and a hammer to the left over bits. . . they'll knock out alot easier
Done a couple of cars now, by far the quickest way
just about sorted it now, what a nightmare!
Seen quite a few reports about Floflex on here and other forums and as far as the fitting goes, they appear to fit quite well apart from the nightmares with the rear wishbones.
As far as handling goes we'll see.
good value for money.
Thanks again for all your help.
155lee
Sep 6, 2016 11:10 AM
The Enigma
Sep 12, 2015 10:12 PM
truffleshuffle
Sep 10, 2015 09:35 PM
