changing a turbo from 2wd to 4x4
Old Jun 24, 2010 | 09:52 AM
smartrs's Avatar
smartrs
Default changing a turbo from 2wd to 4x4
how is it done do you turn the compressor housing or the exhaust housing ? and what the best way to get to the bolts connecting the old turbo to 4x4 manifold
Old Jun 24, 2010 | 01:38 PM
smartrs's Avatar
smartrs
anyone ? i'm sure its quite simple and i'm just being a bit thick today
Old Jun 24, 2010 | 05:57 PM
smartrs's Avatar
smartrs
32 viewers and still no one lol may be i'm not as tick as i tought today lol
Old Jun 24, 2010 | 06:09 PM
retro d's Avatar
retro d
Dont know think you just turn the comp housing round if needid, as for the bolts I usualy depending how tight they are, remove the four bolts that hold the turbo to manifold and remove the studs in situ as this makes it easyer to come out.
Then when refitting do the same and fit the studs in when you got the turbo flange in place.
Hope this helps you. ?
Old Jun 24, 2010 | 06:13 PM
COLEYST200's Avatar
COLEYST200
just undo the bolts that hold the front housing slip it round to were you need it thats all job done
Old Jun 24, 2010 | 06:20 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
Think you may need a bracket for the actuator, depending which way your going 2wd>4wd or 4wd>2wd
Steve
smartrs's Avatar
smartrs
then the oil feeds and the water feed are in a different place ??? and also the oil drain
Old Jun 24, 2010 | 06:22 PM
smartrs's Avatar
smartrs
its a 4x4 manifold and the turbo is set up for 2wd manifold
Old Jun 24, 2010 | 06:37 PM
retro d's Avatar
retro d
If thats the case you need to undo the main bolts at the back of the turbo, just try and loosen them however they can be very tight and snap , depends if its a new/recon turbo tbh. best thing to try is put it in a vice, slacken all bolts find a nice bar that fits into the turbo feed hole and try to move it round.
The actuator bracket is on the front of the housing so you will need a longer rod actuator and bracket.
I have one if you need it fella>??
Old Jun 24, 2010 | 06:38 PM
Moonstone Steve.
does the front and rear turn independantly from the centre, i have changed a T34 from 4wd to 2wd but cannot remember how i did it.
Steve
Old Jun 24, 2010 | 07:03 PM
retro d's Avatar
retro d
You can turn the centre part round that has the oil feed/water. and also the front housing.
Old Jun 24, 2010 | 07:04 PM
jon@work's Avatar
jon@work
You'll need to spin both the exhaust and the compressor housings.
Don't forget you'll also need a 4x4 oil return, and sort out an actuator mounting bracket.
To get the turbo onto the manifold, you'll have to drill out/unscrew the 4 mounting studs and enlarge the holes.
If the turbo is getting on, you really will struggle with moving the exhaust housing. If it needs a rebuild, you'd perhaps be better off getting a shagged 4x4 turbo and having that rebuilt instead.
Old Jun 24, 2010 | 07:36 PM
smartrs's Avatar
smartrs
i got the oil return from the turbo that is on there now and the turbo has a bracket and i have one from the other turbo, the turbo also has the actuator mount already on the compressor housing will this be any good ?
the exhaust housing has 4 holes in it is this the part you say needs drillng out ?.
guess this will ll become apparent when i get the old turbo off i can use that as a template and line things up just having issues with the 2 bolts nearest the head ..... i cant bloody get to them , any tips
Old Jun 25, 2010 | 09:28 AM
smartrs's Avatar
smartrs
grrrrrr still cant get the old one off dont help with broken ribs lol
jason_nike
Aug 18, 2019 10:53 AM
MARKYMARKONE
Aug 20, 2015 12:55 PM
IAN RS2k
Aug 18, 2015 07:51 PM
lockie
Jul 31, 2015 10:03 PM
Old ford
Jul 31, 2015 06:50 AM
