General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
i dont know if you can buy them but u will need lowering blocks for the leaf springs. Remove the shackles and fit the lowering blocks between the leaf springs and the axle. You might need longer shackles too. The fronts should be the same as a car.
ok then ill have alook to see if i can buy them i heard of swear ive seen that you can take them of and turn them upside down is this ture or am i chatting bull..
and ok the front will be easy
erm im not sure mate the paintwork it pretty good.
but the bonnet needs to be be g3'd because it has white residue on it but i was not bothered about the paintwork on here peoeple where saying rust rust rust and this has hardly any at all
yeah i was thinking getting proper springs donw want to go through the hassle of cutting etc.
markb- so you can turn them around then, was not jsut me hearing things.
but i am going down the lowering block method which will be alot easier aswell
cheers for all the replys
