ST170 Sump Question Torque setting for bolts?
Are they the same sump as the 2.0 Zetec engine?
Mine has gone porus and I need to order a new on from my local panel factors.
Do you need to remove the cat to change the sump as the sump does look shallow?
What is the torque settings for the bolts? I dont want to go and squish all the sealer out
Bloody hell how much.I was round my mates last week,his mate has a ST170 and his was leaking,my mate had a spare 2ltr zetec sump lying about so they put it on.Its a small sump/pan isnt it.
Ah right, good job you told me that. I wont be buying the gasket then. Id better ring ford and check they have some in.
Hope its not too expensive.
Phoned ford and they are getting me some sealer for tomorrow. The parts guy was trying to tell me the focus st170 sump isnt the same as the other Zetecs!
what sump have you bought? They both fit the engine i have used both,the only thing i can think of is it might not clear your down pipe
track.focus'd
Aug 12, 2015 05:53 PM
