Squeeky sound when accelarting? HELP!
Old Jun 21, 2010 | 05:12 PM
Ryan_3's Avatar
Ryan_3
Default Squeeky sound when accelarting? HELP!
Got a squeeky soun dcoming when im acclerating. what can be the cause? it mainly does it from first till third. its an escort mk4 with a 1097cc kent engine.
I need to change a bellow, not of the shafts, other, maybe that a steering linkage??! maybe its coming from there
Old Jun 21, 2010 | 05:21 PM
NoRubNoDub's Avatar
NoRubNoDub
McGarrity Motorsport
The Kent 1097cc is a small mouse in a wheel connected to the output, it mite be tired?
Old Jun 21, 2010 | 05:33 PM
Ryan_3's Avatar
Ryan_3
knew someone would say that lol.
Someone have any ideas? apart from mice in me engine lol
Old Jun 21, 2010 | 05:37 PM
NoRubNoDub's Avatar
NoRubNoDub
Check the engine and gearbox mounts
Old Jun 21, 2010 | 05:40 PM
Ryan_3's Avatar
Ryan_3
will do. can it be the belt aswell?
Old Jun 21, 2010 | 05:52 PM
NoRubNoDub's Avatar
NoRubNoDub
Is it a quick squeak or a sreech?
Old Jun 21, 2010 | 05:54 PM
Ryan_3's Avatar
Ryan_3
last maybe 2-3 seconds!
Old Jun 21, 2010 | 05:57 PM
NoRubNoDub's Avatar
NoRubNoDub
Does it squeak if you put it in gear and bring the clutch up to the bite point?
Old Jun 21, 2010 | 06:01 PM
Ryan_3's Avatar
Ryan_3
didnt take notice. it does it for example when it is in second gear and you put it in third and accelarating.
Old Jun 21, 2010 | 06:03 PM
NoRubNoDub's Avatar
NoRubNoDub
Try it out
Old Jun 21, 2010 | 06:09 PM
Ryan_3's Avatar
Ryan_3
so I will put it in first gear and keep it at the biting point? if it does it can it be that the clutch is fooked?
Old Jun 21, 2010 | 06:13 PM
TOMMY_RS's Avatar
TOMMY_RS
SHITE!
sounds like belt to me, put some wd-40 on it, then go for a drive to warm it up, cos wd-40 can preish rubber aparntly lol, but if you drive it for a bit it burns off so will be fine
Old Jun 21, 2010 | 06:15 PM
Ryan_3's Avatar
Ryan_3
will do mate aswell cheers
Old Jun 21, 2010 | 06:29 PM
NoRubNoDub's Avatar
NoRubNoDub
I've a funny feeling it's a trust washer making the belt squeck when the engine is under load
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
Fudgey
21
Sep 30, 2015 06:19 PM
Brickhouse
Sep 23, 2015 06:28 AM
