General Car Related Discussion.To discuss anything that is related to cars and automotive technology that doesnt naturally fit into another forum catagory.
i use brick acid from b&q..strong as fook..if you use it be careful not to put too much down as it will eat away at the brick.. works perfect if you use the correct amount
i used a swarfega brick cleaner, probably not as strong as the acid(didnt want to ruin my new drive) but nothing a bit more elbow grease with a brush didnt sort out.
[QUOTE=Spax;4963204]remove the bricks and turn them the other way up? [/Q
still wouldnt work i have a ford,will just keep leaking haha joke...just wanted a good cleaner that gets rid of it all and don't leave the stains there
