escort van any problems i should be aware of ?
Hi there guys found an escort van,
1998 with 96,000 miles.
only problems on it are few scabs on paintwork (not a problem for me)
all clean inside and out.
what problems do these vans suffer from. its cheap enough. jsut dont want to get bitten in the ass.
Reliable as a primus stove, mainly due to their simplicity. No ECU or engine electronics to worry about, they're pretty old school
As mentioned rust is what generally takes these off the road, rather than mechanical failure.
Obviously standard rules apply, an engine with service history has half a chance of being better...
right great news guys at least i dont have to worry about electronic's liek all cars these days.
will be going over it with a fine tooth comb to check for any rust at all on the van and will check everywehre else you have all mentioned cheers for that and hopefully in about 2 days time ill be the owner and wil post pictures
only being used to advertise my wrapping buissness so not going anywehre fast.
can you smell purple?
From: normally dewsbury west yorkshire, but i could wake up anywhere!
crackin motors, look for roy across the rear cross member above the shock absorber mounts as these can be costly to repair. same again avross the rear. the engines will last forever if theyve been looked after. a high miker with history is always better than a low miler with no history.
happy hunting
happy hunting
have a look at
http://www.eodc.co.uk/forums/index.p...n/page__st__25
theres some pics with examples where they go rotten
Bombproof really but do the belts unless the guy can 100% prove they have been recently.usual escort probs with fuseboard,lower arms go clunky and of course rust but IMHO best vans by far for the money/size as the ford transit is the greatest van ever bar none but a big old girl!!!!
