saff cosworth fan relay
Old Jun 20, 2010 | 04:14 PM
smartrs's Avatar
smartrs
Default saff cosworth fan relay
my fans are not cutting in on my saff and i think i narrowed it down to the relay (i think) where can i get a new fan relay from ? or any other ideas on wat it can be ?
Old Jun 20, 2010 | 08:22 PM
Are you on the oe set up, ie through the fusebox ?, if so ditch it before a fire starts, and make a seperate loom.
The relays are std fit SPST relays, someone like www.vehiclewiringproducts.co.uk do these as well as most car shops.
Just be aware that there are two types of pin layout, known as type S and type B, so check this.
Old Jun 20, 2010 | 08:28 PM
smartrs's Avatar
smartrs
has any one got a digram for the bypass loom ? as it is probably a good idea to replace this need to do the fuel pump too were do people fuse these bypass looms to keep things looking neat ?
Old Jun 20, 2010 | 09:42 PM
RS_Andy's Avatar
RS_Andy
Hello Smartrs, have a look at this post I had the same problem, all sorted now by making my own loom
https://passionford.com/forum/techni...ml#post4961677
Old Jun 20, 2010 | 09:43 PM
Tev's Avatar
Tev
have you by anyhance swapped over to a lly rad?
Old Jun 20, 2010 | 09:55 PM
smartrs's Avatar
smartrs
no still standard rad but the engine has just been rebuilt so the rads been off the car
Anutternutter
24
Aug 31, 2015 01:24 PM
Anutternutter
Aug 21, 2015 06:07 PM
James Porter
Aug 14, 2015 12:43 PM
Aug 14, 2015 07:29 AM
