52 reg focus 1.6 engine swap no fuel
Old Jun 20, 2010 | 04:00 PM
jools123's Avatar
jools123
Default 52 reg focus 1.6 engine swap no fuel
ive just replaced the engine on my focus im getting a spark but im not getting any fuel through? any ideas anyone as im stumped. something i could have left un plugged? immobiliser? i have no idea. any ideas or anything gratefully recieved
Old Jun 20, 2010 | 06:09 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
there is a fuel cut off on the driver or passenger side floor well behind a cover trim
push the red button it should fix it
tommy
Old Jun 21, 2010 | 05:22 PM
jools123's Avatar
jools123
thats all fine any more ideas people???????
Old Jun 21, 2010 | 09:13 PM
xr3iturbo's Avatar
xr3iturbo
ON THE ROAD AGAIN
well the only other thing i could think of would be
crank pic up sensor
cam pic up sensor
can yo uhear the pump priming when you first turn the key ????
Old Jun 22, 2010 | 08:52 AM
Rema-d's Avatar
Rema-d
could be pump not getting proper connection, check wires on pump, and as ^^^^^^^ when you turn the key make sure you hear the pump priming. start from there and follow it to the engine
Old Jun 22, 2010 | 10:02 AM
Do you not need the keys and the ecu for the new engine you have just fitted?I could be wrong though.
Old Jun 22, 2010 | 12:48 PM
martysmartie's Avatar
martysmartie
Does the fuel pump prime when ignition is switched on? If not this would indicate the CPS is not functioning, re check you have reconnected all connections as well.
You do not need to have keys if you change the engine, you would however need the corresponding keys (Transponder) if you swapped ECU.
Martin
JoeyBoyden
Jan 4, 2024 02:36 PM
RUBY123
Oct 22, 2023 12:04 PM
Rickyrustyfox
Aug 13, 2015 01:11 PM
track.focus'd
Aug 12, 2015 05:53 PM
vdubo7
Aug 2, 2015 08:17 PM
