Any heating experts in the house?
Old Jun 20, 2010 | 09:09 AM
Rhys's Avatar
Rhys
Default Any heating experts in the house?
Quick question, my vailiant ecotec pro bolier this morning has come up with low pressure F22 warning. It only has 0.5 bar in the system. I have not changed anything in the house etc. Tried resetting the bolier but the pressure does not increase. Any idea if i can do anything to fix it?
Old Jun 20, 2010 | 09:13 AM
markk's Avatar
markk
yes , refil it and find the leak.
Old Jun 20, 2010 | 09:37 AM
Rhys's Avatar
Rhys
Question was how do i refill it?
Though i have just worked it out while typing this! Presume it must have been low for ages as i had to change a tap over and turned water off etc. I think drained some or a lot of air out of my stupied towel rail. A good old messing around with some levers on the boiler and it has now worked! I like nice and easy fixes lol.
Now i can go and have a shower......
Old Jun 20, 2010 | 09:58 AM
Was it a filling loop by the main stopcock ?, that's how I do mine, loses 1 bar every 3 weeks!!
Old Jun 20, 2010 | 10:03 AM
Moonstone Steve.'s Avatar
Moonstone Steve.
Sould have a flexi pipe with a tap each end m8, turn the taps on to fill the system and keep an eye on the gauge whilst doing so as to not over pressurize it.
Steve
Old Jun 20, 2010 | 10:16 AM
Rhys's Avatar
Rhys
I just done as Steve said above. TBH i have never checked it! Will keep eye on it now over next few weeks. I have one of those magnaclean things too. It looks like it could with cleaning. Anyone know if this is an easy job, or should it be best left to the experts?
Old Jun 20, 2010 | 10:44 AM
TIFF's Avatar
TIFF
Chasing Radders
Someone has a pretty big leak somewhere!!!!!!!!
If i was you i would add some of the leak stopper from a plumbing merchants
Old Jun 20, 2010 | 12:43 PM
Steve the Plumber's Avatar
Steve the Plumber
The original Rouge Trader
Do it properly, and try to find the leak and get the leak repaired! If you keep repressurising the boiler/system, you will eventully (SP) killing the boiler and filling the system with lots of carbon sludge!!
Old Jun 20, 2010 | 02:45 PM
Rhys's Avatar
Rhys
Hopefully mine was a one off. Well never had a problem before.
Anyone kown about my question above about the magnaclean?
I have told the landlord that I have to keep topping the pressure up, he says, it's only water, tight arse that he is, took him 8 months to replace a tap, that's what you get for renting off a mate I suppose!!
If it's gets damaged it's down to him, he tells me the concrete floor would need digging up to find the leak ?
Old Jun 20, 2010 | 03:32 PM
nrg dub's Avatar
nrg dub
magnaclean's have had a recall with there rubber oring seals on the lids leaking
There easy to clean turn both the valves off eather side open the air bleed up to make sure they are def off use the big magnaclean spanner to remove the lid
If the oring inside the top is RED/ORANGE then it needs changing for a black one
Old Jun 20, 2010 | 04:26 PM
Rhys's Avatar
Rhys
Cheers mate! I will have a look. If i had said O ring above will i be able to refit until replacment comes? As i cant be without boiler working. Might have a go at cleaning it in the week.
Old Jun 20, 2010 | 06:46 PM
nrg dub's Avatar
nrg dub
yehr u can refit it no real prob just use some silicone greese on the old oring and some ptfe round the thread on the canister
The only thing wrong with the old oring is when it heats up then cools down it can sometimes create a leak which only show up when the system is cold
if u have no luck finding new orings i have some on my van that i could bung your way
fordrallycar
Sep 30, 2015 07:57 PM
DavidK
Sep 27, 2015 02:55 PM
