3dr rear beam
Old Jun 19, 2010 | 01:16 PM
rs tingle's Avatar
rs tingle
Default 3dr rear beam
hi would could any one tell me if a 3dr rear beam basically full rear end fit straight onto a 2wd saph cosworth an is the 3dr petrol tank the same as a 2wd one
Old Jun 19, 2010 | 04:17 PM
Alvyn's Avatar
Alvyn
the brackets for the roll bar are located in different places but easy to remove and weld in the approiate place! tanks are the same iirc
Old Jun 19, 2010 | 04:30 PM
rs tingle's Avatar
rs tingle
iv got both 3dr door an saph ream beams coplete jus wonderin which to use as i not the diff on the 3dr is good but i dont now bout the one on the saph i could swap the diffs over is there any difference in 2dr diff an a 2wd saph cossy one
Old Jun 19, 2010 | 04:31 PM
rs tingle's Avatar
rs tingle
iv got both 3dr door an saph ream beams complete jus wonderin which to use as i now the diff on the 3dr is good but i dont now about the one on the saph i could swap the diffs over is there any difference in 2dr diff an a 2wd saph cossy one
Old Jun 19, 2010 | 05:37 PM
Alvyn's Avatar
Alvyn
same m8
Old Jun 19, 2010 | 05:42 PM
rs tingle's Avatar
rs tingle
Cheers mate
Old Jun 19, 2010 | 07:50 PM
You'd be better off using the sapphy stuff, as the arb doesn't do anything really on the 3 door, the shorter sapphy one makes a hell of an improvement, just need to weld 2 points on chassis type bit that holds rear diff hanger for the bushes/clamps for the arb that's all.
There are 3 different tanks used on 3 door and 2wd sapphy, but all fit each other, most of the difference is on the upper edge nearest the fuel filler corner of the tank.
If you have a few to choose from choose a "made in canada" one, as have better swirl pots.
jessie_rs
62
Aug 6, 2019 09:27 PM
yatta
May 21, 2016 10:31 PM
Ford Focus RS Parts for Sale.
Mar 9, 2016 01:03 PM
Nov 5, 2015 08:12 PM
Nov 3, 2015 04:08 PM
