Jetting the boost (amal) valve
Back in black!
Anybody know how much you need to open each port on the amal valve to get it to hold 32psi as my greddy boost controler has stopped working
so the amal valve will have to do for now
anybody got an idiots guide please
so the amal valve will have to do for nowanybody got an idiots guide please
restricting the compressor port increasing the r port raises boost
you have to adjust the ratio between these to ports to obtain a reasonable boost curve
This also depends on your ecu and boost map
the bigger your r port the bigger the over shoot
Back in black!
cheers for that will have a play about tonight, question though is what do you mean by over shoot?
and what would be a good start size to open the r port up and taking the comp port down to
cheers
Mark RS
Oct 12, 2015 06:01 AM
Russ Payne
Sep 25, 2015 08:29 PM
