Mondy TDCi DMF and clutch, DIY?
Old Jun 18, 2010 | 07:23 PM
plynchy's Avatar
plynchy
Default Mondy TDCi DMF and clutch, DIY?
As title, this is easy enough to do DIY?
I've had the Cossie in bits dozens of times, so is there anything on the Mondeo that will phase me? Apart from the parts cost that is...
While i'm on, rear shockers on the estate (2004), been quoted £50 labour to do them. Worth getting my hands dirty for?
Old Jun 18, 2010 | 07:35 PM
DanW@FastFord's Avatar
DanW@FastFord
Spelling Club King!
Dampers are a piece of piss, if you can get the car in the air. But if you're doing it on your drive I'd pay 50quid to save messing about on your back.
DMF/clutch/release bearing isn't technically hard, just a lot of bolts! The biggest challaenge is lowering the subframe enough to get the box out.
Old Jun 18, 2010 | 07:38 PM
st3v3's Avatar
st3v3
The subframe has to be lined up spot on when you put it back together else the car will drive like a dog.
Old Jun 18, 2010 | 09:36 PM
jonnyboy's Avatar
jonnyboy
clutch kits now available witha solid flywheels,far cheaper than the kits with a dmf.
and what everyone else says about the engine bed.needs proper alignment pins or mark the floor clearly
Old Jun 18, 2010 | 10:29 PM
Karl 3dr's Avatar
Karl 3dr
As said, the subframe is the worst part, i'd take it off completely if i were you, after that, its pretty straight forward.
I'd be careful of the solid flywheel conversion though, i drove a Transit with one in this week and it was horrible, the whole van just vibrated, not nice!!
Old Jun 19, 2010 | 05:29 AM
plynchy's Avatar
plynchy
Cheers for the advice.
I'm considering the solid conversion, but the DMF thats on has been good for 112k so I figure the rest of the car will be dead before another one wears out.
Old Jun 19, 2010 | 08:18 AM
DanW@FastFord
Spelling Club King!
It's only worth fitting a solid fly if you're a taxi driver and expect it to go again during your ownership of the car.
Old Jun 19, 2010 | 08:46 AM
TIFF's Avatar
TIFF
Chasing Radders
I have just had a new DMF and Cutch in my Mondeo...... £150 labour it cost me....
Dont go for the solid conversion.......Ford didnt spend milions for no reason..
Old Jun 19, 2010 | 08:51 AM
Matt Evans's Avatar
Matt Evans
Black Country RSOC
Different car altogether but similar issues. I managed to screw my DMF and clutch up on my remapped TDI octavia estate, and went for the cheaper solid flywheel / clutch option.
It was "OK", but there was an underlying vibration that i could always feel through the clutch pedal which really got on my nerves after a while.
Like the OP has said if the OE set up has lasted 112k, that aint too bad tbh, and will you still have the car when its done 224k?
If you can afford it, id go with DMF all the time, like Tiff said if ford could have got away with a normal solid flywheel, they would have done.
Old Jun 19, 2010 | 08:55 AM
ive done a mondeo clutch before. Ive never changed a flywheel though. When i did the clutch i just moved the gearbox onto the sub frame and removed the clutch through the gap between the engine and box. You might be able to do the same with the flywheel.
mark94
Ford Mondeo Including ST
Oct 10, 2023 06:52 PM
arkeye
Ford Focus ST
Feb 20, 2016 01:22 PM
The Enigma
Sep 29, 2015 10:31 AM
Sp3no
Sep 27, 2015 07:23 PM
