Has anyone ever used Foliatec Caliper paint?????
Old Jun 18, 2010 | 04:35 PM
tosh's Avatar
tosh
Default Has anyone ever used Foliatec Caliper paint?????
I'm going to paint some new calipers with it, but the instructions say only mix up a bit at a time because it goes hard, so my next question is in your experience with it how long did you get before it was unusable.
Old Jun 18, 2010 | 04:39 PM
Moonstone Steve.'s Avatar
Moonstone Steve.
I have always mixed enough to do two calipers and it has never going hard before finishing.
Steve
Old Jun 18, 2010 | 05:29 PM
tosh's Avatar
tosh
Cheers Steve, It's just that I emailed the manufacturer in Germany because the instructions did not give any clue as to how long it lasts once mixed, and there exact words were:
You can use the mixed caliper paint for approx. 10 minutes. Please only mix
as much as you want to use for the moment. Otherwise it will be useless.
Which seems a tad confusing because the instructions say mix the hardener to the paint @ 3-1 ratio leave to stand for 5-10 Min's then mix again, so I had a vision of going back to use it and it being a hard lump in the tin
Did you have enough to paint all of your saph calipers or was it tight.
Old Jun 18, 2010 | 05:31 PM
RichieST's Avatar
RichieST
I've always used hammerite, never had a problem!
Old Jun 18, 2010 | 05:35 PM
tosh's Avatar
tosh
I found that Hammerite goes soft when it gets to hot so I thought I would try the Expensive shit, will probably regret it
Old Jun 18, 2010 | 05:40 PM
dingla rs's Avatar
dingla rs
sounds like a loada old tosh 2 me shudn't go hard for over hour in the mixed pot will dry quick on caliper tho
Old Jun 18, 2010 | 06:44 PM
Xr2iTurbo's Avatar
Xr2iTurbo
i used it about 10 yrs ago on a rover i had and it never fully went hard,i mixed the full tin all at once and got them all painted no problem,the car was on 4 axle stands,the fucking stuff never went off fully and sprayed off after 2 days on a set of newly powder coated comps! I was well pissed only use hammerite now i think it covers the best,i used metalic black on mine,my advise dont use it mate
Old Jun 18, 2010 | 06:54 PM
Moonstone Steve.
One pot was enough for all four calipers m8, but only mixed enough to do two at a time.
Steve
Old Jun 18, 2010 | 07:04 PM
Anyone used the Larkspeed Bubblegum Pink caliper paint, as wondering what the finish is like, want this on me tarox cali's.
Old Jun 18, 2010 | 10:56 PM
tosh's Avatar
tosh
I hope it lasts that long as I'm a slow worker.
I won't mind if that happens I was going to get the wheels painted black anyway
Steve
Cheers pal.
I was going to get the pink but I thought it would clash with me fury dice so I settled for the black
Old Jun 19, 2010 | 09:03 AM
I've got red hammerite etc but thought pink would be a nice change, might attract the ladies too, till they see a fatcnut sat in the drivers seat ha ha!!
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
muzzman1
Sep 30, 2015 08:59 PM
rsguy
44
Sep 29, 2015 03:29 PM
Sp3no
Sep 27, 2015 07:23 PM
