Cosworth Engine and box in Ireland
2wd Cosworth Turbo engine and Box for sale,
Came out of a Sapphire Cosworth I broke and was running very well.
Has had a Complete Top end Refurb with a Grp A head gasket fitted and Cometic Inlet and Exhaust gaskets, new valve stem seals, valves cleaned and lapped in etc.
Everything included to do conversion, all ancilliares, ECU, Clutch, Wiring Etc.
Also T5 Gearbox included in very good condition.
€2200 o.n.o. for everything, may split engine and box if I get enough intrest in both.
What block 200 or 205, standard or bored, pics? Does it come with mounts for engine and trans, shifter, boot/gator and console trim around shifter, air box, will need propshaft, and is the lsd 7 or 7 1/2
What all comes with the engine, what kind of condition is it in, mileage, wear, mods, turbo, injectors, cams, etc etc..got any pictures to post to me nzwinrz@msn.com. I'm looking for as much as I can get from one seller, doing a Cossie engine in a Merkur XR4Ti
big_Rad
Sep 15, 2017 09:36 AM
Aug 14, 2015 07:29 AM
wheelwizardrefurbs
Aug 4, 2015 06:23 PM
thats if he ever starts it lol, you have any rwd parts lying about you
