What Boost controller?
Old Jun 18, 2010 | 08:36 AM
Icekottarinn's Avatar
Icekottarinn
Default What Boost controller?
I have Sierra Cossie 380 hp, -34, t34.55, Map 3 bar, and I am using the Amal valve.
But I am not getting steady boost and want to hear what you guys are using for this setup.
What Boost controller is the best buy for this setup?
Thanks for your comment.
Old Jun 18, 2010 | 09:47 AM
cossie4i+'s Avatar
cossie4i+
TT T38 Power
Im still using a amal valve on mine and my boost stays at 2bar from 3500 - 7500
Steve
Old Jun 18, 2010 | 10:37 PM
English's Avatar
English
My AMAL valve is long gone, although the nerds on here will know how to make it work better
Could change to an external wastegate. That usually makes boost more stable, but pricey.
I do have an external wastegate, and I'm using a manual controller that works on the principle of an external wastegate, in that it has an adjustable spring pressure that only allows the wastegate to see boost, and therefore open, once the desired level of boost has been reached.
The main advantage is it's SO easy to install, adjust, and it's SO CHEAP!
In fact, you could likely install this on the airline to your turbo wastegate, keep using your AMAL valve, and still see an improvemnt in turbo response and steadier boost up top.
Here's a link: http://cgi.ebay.com/ebaymotors/NXS-M...Q5fAccessories
There seem to be lots of companies selling them, some are UK based too
Make sure you get this set up on a dyno or have your air/fuel checked, or the money you save buying it could be spent on your melted engine
Old Jun 19, 2010 | 08:19 PM
cossie604's Avatar
cossie604
My Cossie is still on its Amal valve, but my Mitsubishi runs a Blitz boost controler. Awesome bit of kit once you've sussed it all out....deffo going to get another for the cossie.
Old Jun 19, 2010 | 09:56 PM
WongRS's Avatar
WongRS
Apexi AVC-R is a great bit of kit, if you've got a spare £500.
Old Jun 20, 2010 | 08:45 AM
cossie604's Avatar
cossie604
The Blitz controler is a bit more expensive than the Apexi but tbh its probably just name tax your paying the extra for....
http://shop.edoperformance.co.uk/bli...k-p-10715.html
Here's a pic of the controler Im using in the GTO along with a pic of the Power meter Ive got hooked up to it. The two together make a unit thats around din size, making installation quite easy in most cars.
Old Jun 20, 2010 | 10:30 AM
J1mbo's Avatar
J1mbo
B1mbo
air injectors
Old Jun 20, 2010 | 09:32 PM
ybturbo's Avatar
ybturbo
I use Greedy Profec B spec II and it's quite good but I have to admit that the Apexi AVCR is better because it has boost control depending on gear selected if you like! That means that you can use low boost for 1st-2nd gears to reduce wheelspin and higher boost to the rest of the gears! Quite impressive!!!!
Old Jun 20, 2010 | 10:43 PM
Stu @ M Developments's Avatar
PassionFords Creator
Having used almost all controllers on your type of car id recommend one of the following:
Best manual:
http://cgi.ebay.co.uk/ws/eBayISAPI.d...e=STRK:MESE:IT
Best of the cheap electronic:
Best... period:
Old Jun 20, 2010 | 11:38 PM
clarke5700's Avatar
clarke5700
YES I KNOW I CANT SPELL
Best manual:
Best... period:
the top 2 links are the same
Old Jun 20, 2010 | 11:55 PM
SS1's Avatar
SS1
FLAWLESS
Old Jun 21, 2010 | 06:49 AM
Groan... too much beer. Fixed now, sorry.
Old Jun 21, 2010 | 10:56 PM
cossie604's Avatar
cossie604
Too much beer, before 8am? Fuck me you northeners are hard core
Old Jun 21, 2010 | 11:38 PM
rs_daz's Avatar
rs_daz
Does anyone run the Gizzmo controllers?
Old Jun 22, 2010 | 01:10 AM
Icekottarinn
Sorry, I am still trying to insert a signature picture.....not easy.
Old Jul 4, 2010 | 12:28 AM
Icekottarinn
Thanks guys, I have not yet bought a boost controller.
Has anyone tried this one:
http://www.boostcontrollerstore.com/...-Kit-p-15.html ?
And one more thing, IF I buy a good boost controller, will I be able to have 2,2 bar at all time with my T34.55?
Or will it as now with Amal valve, go in peak to 2,2 and drop to 1,6 bar?
Finally, I would be interested in buying a good used boost controller..
Old Jul 4, 2010 | 12:36 AM
fiend's Avatar
fiend
That just looks like an expensive bleed valve, you would be better off with a proper electronic boost controller.
Old Jul 4, 2010 | 09:17 AM
Papillon's Avatar
Papillon
i used blitz dual sbc spec s when i was running stage 3, its only reommended for 1.3bar so boost was a bit unsteady over that but it made my car come alive. im going for a spec r now which can handle 2.5bar.
Old Jul 4, 2010 | 09:54 AM
bad boy rs's Avatar
bad boy rs
im using one of these, great bit of kit
http://cgi.ebay.co.uk/BLITZ-DUAL-SBC...item483ae74b9d
timsrs
Nov 13, 2018 11:48 AM
Mark RS
Oct 12, 2015 06:01 AM
fordrallycar
Sep 30, 2015 07:57 PM
stevecfrst1
Sep 30, 2015 05:18 AM
Russ Payne
Sep 25, 2015 08:29 PM
