stage 3 breather system
Old Jun 16, 2010 | 10:45 PM
richbogle's Avatar
richbogle
Default stage 3 breather system
whats the best way to rig up stage 3 breather system from start to finish?? does the rocker need to breath? i thot id did. is that why im geting smoke on ever-run? b4 and after a re-build...
Old Jun 16, 2010 | 11:11 PM
ajamesc's Avatar
ajamesc
cossie fan (unluckerly)
AT the end on the day id say its best to breath from the rocker aswell and let the hole system breath to atmosphere aswell via a vented catch tank!. Hot oil produces condensation so it needs to vent to atmosphere if u take a truck engine apart and thats an engine that runs 6 days a week for 8 hours a day!. If serviced are as clean as a new engine inside with over 800,000kms on the clock!. Id put this down to the breather systems being so affective and always venting to atmosphere letting all the shit and condensation escape from the engine!. Well apart from this new euro 5 ballshit were trucks have egr putting all the shit back into the engine lol.When i did my exhaust manifold gaskets not so long ago i took my catch tank off for room and when i turned it upside down to empty it u should have seen the shit that came out of it if id had a closed breather system then all that dirty oil condensation water would still be inside my engine!
Old Jun 17, 2010 | 07:36 AM
carlo's Avatar
carlo
I got andrew gallacher to set up the breather on my cossies breathing from both sides of the block with a return welded into the sump never had any bother scince.
Nov 1, 2015 06:53 PM
gcfcos
59
Oct 6, 2015 05:04 PM
Mc5506
Oct 5, 2015 09:57 PM
XR4
Ford XR Range
Oct 1, 2015 12:46 PM
